Vacuums Logo
A
Anthony Richard Posted on Jan 31, 2015
How do I reset Electrolux deepclean motor
Disassembly to look for reset button and confirmed voltage a vacuum head
Electrolux Epic: POWER NOZZLEM NOT WOKING
Connect power head directly to power without wands and see if’s working
If it’s working you have problems in wands or true hose
If power head is not working directly connected to power you have problem with reset switch or power head motor
Try to push reset switch several times
You have to test hose and wands for continuity and eliminate things by things
Electrolux Oxygen3 Ultra head works for 5 seconds then reset trips. I reset it and it works for 3 seconds and trips again. The beater bar is completely clean with a new belt, filter and bag. Ideas?
Try condenser if not it might be loss of electrical if in area of drop on voltage check what voltage supply you have or try a different soket hope this helps.
2answers
Would like to know if there is a reset button on the Electrolux Upright Vacuum Cleaner! Model # EL5010 Type :A-1
Hi, check the troubleshooting on page 19 of the manual. I does,'t mention a reset button but I would imagine that it has a self-resetting thermal switch which could take half an hour for the motor to cool down (fairly common).
Electrolux EL5010A Manual
Power head will only work when and only when the reset button is pressed. What is the problem?
It's either a faulty nozzle reset switch, the belt was replaced with too much tension, or the pn motor needs svcd. or replaced.. Hope that helps!
Remote control Electrolux flashes 3
Can you give more information...what model and what is happen.
Electrolux power nozzle quits working after just a few minutes of working. i've cleaned the head, but have to push the restart red button for it to go again for a few minutes
My guess is that hair, threads, and/or similar long fine fibers have gotten wrapped around the ends of the brush near where the bearings are. The PN may need to be disassembled to remove them. Be aware that if the vacuum is less than 5 years old, disassembly by anyone other than an authorized service tech will void the remaining warranty.
My recommendation is to take it to an authorized Aerus Electrolux store and let the tech perform a free service check. He/she can let you know what the problem is and for a nominal charge, probably repair it on the spot.
http://www.aerushome.com/storelocator/
I vacuumed a shirt. It came out immediately and there is now visible damage. The suction is working but the rotary piece with the brushes is not
Have you pressed the reset button on the power nozzle? If the power nozzle motor isn't running, this is the problem. If the PN motor is running, the problem is more likely to be a broken belt, and it needs replaced.
If the belt, I strongly recommend taking it to an authorized Aerus Electrolux dealer to have it replaced. It can be tricky disassembling and reassembling the PN without damaging something.
Central vacuum won't start even after depressing the reset button on the carpet sweeper. Hose and wand appear to be unclogged.
Is it only the power head that's not working, or the central vacuum itself? Disconnect wands from hose, turn on, and hold hand over hose end to check for suction. If none, go through first set of steps below.
If the vacuum:
1. Press reset button on vacuum.
2. Check circuit breaker at the circuit box to make sure it's ON.
3. Make sure the unit is plugged in completely.
4. Use a voltage tester to check for power at the outlet.
5. Check filter. If dirty rinse it with warm water, and allow to dry thoroughly. I strongly suggest having a second filter for use during drying, then just trade off using them.
If the vacuum still doesn't turn on, consider the following:]
Broken or worn out power switch in hose handle...Switch needs replaced.
Broken wire in hose...Replace hose.
Bad connection...Needs taken to an authorized Aerus service center for check and repair.
If the power nozzle (suction at end of hose, but power nozzle doesn't work:
1. Ensure the brush has been thoroughly cleaned of any hair, string, and other items that may have wrapped around it.
2. Power nozzle motor runs, but brush doesn't turn when vacuum is on...belt needs replaced.
3. Power nozzle motor does not run...All wiring, connections, and motor need to be checked.
If you can't determine the problem with the above helps, the entire machine, including hose, wands, and power nozzle, needs to be taken to an authorized Aerus service center for complete check.
If you don't know the location of the nearest Aerus Electrolux store, go to below site, type in zip code, and click on "view dealer list". They may also be able to send someone to pick it up.
The reset button on the "sweeper" is only to start the "sweeper" motor after it has shut off due to the brush getting jammed. It doesn't effect the vacuum operation.
Power head on my Electrolux Epic stopped working. Do I need a new one or could there be a part that needs replacing. Can I open it to see?
Have you tried pushing the reset button? I'd try that first. If that doesn't work it could be that the belt is broken. The motors don't go out very often on those.
2helpful
2answers
Lack of Suction
There are actually several possibilities.
Check to make sure that the brushroll is spinning. The brushroll is responsible for virtually all of your pickup on carpet, and is the culprit for most complaints of "lack of suction."
If the brushroll is not spinning, listen at the head to see if the motor inside the power head is active. If you can hear it running but the brushroll is not turning, you have a broken belt. If the motor in the power head is not turning at all you may have an electrical short in the hose, the wands, or the main power outlet from the body of the canister; but before you get too involved check the power head for a thermal reset button. Some of the Electrolux powerheads are equipped with these, and some are not, so check your user's manual. If there isn't one, or if it isn't tripped, you'll need to look for electrical issues.
In this particular model it is fairly common for the electrical contacts on the wands to short out, so inspect the metal contacts to look for scorching, or melting of the plastic around them. If you have access to a VOM, check for voltage at the contacts on the end of the wand, and if it is not present, check all of the contacts sequentially back to the canister body to determine which part is not passing voltage. If you have voltage all the way through the wand, you either have a loose connection inside the power head, or the power head motor has burned out. If you have power from the canister body, but not through the end of the hose, either your hose has a short in it, or the circuit board in the handle assembly that controls the power head power has shorted out.
If your brushroll is turning, then you do, in fact, have a clog somewhere inside the power head, which a visual inspection behind the brushroll and into the elbow will confirm.
Best of luck,
-R
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
