Abode flash player plug in, is telling me it is vulnerable and should be updated now. My other plug ins are up to date, it is just the abode flash player, that won't let me up date it. the plug ins that are up to date are java runtime enviroment
Depending on which browser you are using, go to Tools > Manage Add-ons/Plug-ins. This will bring up a window where it will show which add-ons/plug-ins are installed and up to date. If one needs to be updated, select that one, and update it as needed.
Also, If it is a pop-up/new window that says it needs to be updated, and it already has been update/is up to date. DO NOT CLICK IT. It is a fake site, that takes you somewhere else and can potentially install harmful software onto your machine. ALWAYS do updates through the manufacturer using their update software.
SOURCE: Open ports 24000-24100 on Mac OS X v.10.4.11
System Preferences --> Network --> Sharing --> FireWall --> New --> Port name = Select "Other" and call it (for example) scrabulous --> Add the port numbers 24000-24100 in TCP and UDP ..
SOURCE: runtime error
Dear sir/madam,
what type of game it is? please mention about your game name or what the screen shows exactly.
we can solve this.
thank you
SOURCE: C++ Runtime error
hi its a software problem.. better try to download a new media player classic in a recommended website...
SOURCE: Microsoft Runtime error 6002
To fix this program, you need to rename a folder containing a previous
version of the installer. Open My Computer and navigate to C:\Program
Files\Common Files. Right-click the Installshield folder and select
Rename. You can rename the folder anything, but, as Google suggests,
something like Installshield-old will give you a hint about the
folder’s previous name. Close My Computer and try running the installer again. If that doesn't work tell me and I will see what I can do.
Thank You,
Ryan Frame
Creative Energy Associates Technical Center
SOURCE: error R6002 floating point not loaded
Causes of Runtime Error R6002
Several causes exist behind this error. One of the most prominent ones is a broken link. This link apart from causing the run time error 06002 can also produce other errors like the computer not responding to any instruction at times. If a software has not been properly installed it can also produce such errors. Apart from that, use of internet without any anti-virus software can make your computer applications get infected with spyware and viruses. Such viruses can produce missing links inside your registry causing such errors.
Why are these errors caused? Many computer users are just not aware of the reasons resulting in these errors and what are the solutions to get rid of these errors. Remember, these errors can be solved very simply, and they are not going to cost you money. Usually many people exercise the option of getting professional technicians to resolve these problems. But this is not necessary. Through following the simple procedures suggested below you will be able to eliminate the error r6002.
If you take time and start noticing, you will find that the runtime errors are due to corrupted or damaged registry. You must know that the registry is the most importance place which is a storehouse of all the data, about both the software and hardware installed in the PC. When you uninstall software or remove a device there may be some traces of such actions left in the registry and manually it will be impossible to remove them. You should be having knowledge of computers to do this, since it is not advisable to access the registry without this knowledge and manually delete these files. A wrong move can result in damaging the PC irreversibly.
Therefore the only method to fix the runtime error r6002, along with many other errors, you should use the registry cleaner. With a registry cleaner you can repair the runtime error r6002 all by yourself, without seeking help of technician. This way you can save money and time, and you will also know the action to be taken next time when you encounter such errors.
Using the registry cleaner should be optimized with the antivirus cleaner, and if you program in such a manner that both the virus scanning and registry cleaner can take place simultaneously, for which purpose you should schedule these activities on the computer, and ensure that at that particular time the computer is switched on, without your botheration of checking them, they will do their job on their own, leaving you to attend to your work.
http://www.registryfix.com/?hop=reviewb
