Heating & Cooling Logo
Tracy LeClair Posted on Jan 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an empire dv-60-18pp that the pilot won't stay lit...why?
Fuel on, pilot will lite, when you release the primer the flame goes out...
Shad Willoughby
Level 2:
New Friend:
  • Expert 82 Answers
  • Posted on Jan 30, 2015
Shad Willoughby
Expert
Level 2:
New Friend:
Answers
82
Questions
0
Helped
23414
Points
192
Thermocouple problem. make sure it is in the flame. make sure it is not covered with patina. if it still wont work replace thermocouple.
Why it doesn't stay lit
Replace the gas valve or thermocoupler.
Totai heater wont stay on after lit
Without a pilot flame sensor signal the pilot light will not stay on and the heater won't work. Try Replacing the pilot flame sensor, the pilot flame burns on to it and it connects to the valve. It looks like a wire.
3helpful
3answers
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
So much air blowing in the pilot on DV-35-2SG heater won't stay lit
Unfortunately if its wall vented the wind can hit it just right and pop off the pilot this happens on older models a lot check your vent if its too much of an aggravation you may have to relocate it
Pilot wont stay lit and weak flame
Tap pilot head to knock off any built up corrosion and rust and flame will get better and keep pilot lit
1helpful
2answers
I have an Empire dv 210 gas heaterand pilot wont stay lit
The thermocouple has went bad Here is a link that describes what a thermocouple is how to replace it and has instructional videos
http://www.ehow.com/way_5185498_thermocouple-replacement-procedures.html
I could try to describe the procedure. But the link is more detailed and the videos are really good.
Hope this helps
Please leave feedback
2helpful
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
1helpful
2answers
Empire DV-210: Pilot light will light and stays lit, but when I
The thermocoupler is no good. It's that bulb sitting in the pilot flame. when it goes out it shuts everything doen in the main valve. It has to be kept hot by the pilot, that's how it know whether or not it is safe to open the main .
4helpful
2answers
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Pilot light does not reach thermocouple
the pilot oriface is blocked it needs cleaning out ,
Top Empire Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
