SOURCE: correct torque for rear axle nut on 1997 harley davidson fat boy
Harley manual says 60-65 ft lbs... do NOT exceed this or wheel could seize
SOURCE: need the torques specs for the 2 nuts on the clutch on a harley
50 ft lbs and it is a left is tight nut...don't worry about adjuster nut on clutch just good ole tight will work on that one. compensating nut ( one in front) is 150 ft lbs.
SOURCE: How do you replace the front brake pads on a 2007
Simply loosen the two Torx head screws that hold the caliper on the fork leg,then loosen the small Torx screw and remove it from the caliper, the old pads will drop down. Now you have to compress the two piston or one, back in.Just pay attention when you put back the new pads it must fit into the slot, then the small Torx pin.....Now you just have to put back the two bigTorx screw to reattach the caliper back the fork leg... Another thing IMPORTANT for your safety press the brake lever many time to allow the pads to contact the disc brake....Don't forget this . Voila ...Hope this will help you up.
