We have 3 Uniden phones, no dial tone on any of them. We have unplugged and plugged in with no change. The phone company said it's our phones. What help do you have to offer?
OK, go to the FIRST jack, where the "Line" comes in. At this Jack, use a "Normal" phone, NOT the Uniden, if you can, this is to see if you have Dial tone there, if not, then your problem is on the "Outside" as it were.
Now if you DO have Dial Tone, then try ONE of the Uniden's there at that jack, see if it works OK, if NOT OK, try disconnecting everything AFTER this jack. So that you are using ONLY the line in from the exchange. Terminals 2 & 5, If OK, now, then you have a wiring fault, past that Jack. All phones use connections, 2 & 5 in the BT jack. ALL BT jacks are wired in Parallel. So you would have to find out why you have this problem. (Often it is a staple thru the wire etc).
So line comes in on 2 & 5 the extension wires go on 2 & 5, and go to the "Other" jack. In the master Jack, then we would have 2 sets of wires on 2 & 5, one coming in from exchange, the other going away to another jack. Each subsequent jack, will also have one pair of wires IN & one pair OUT. You MUST isolate each Jack, before working on it, to isolate it from the rest, then connect up, as you proceed with the testing at each location.
Once you establish a "Known Good" then you can test each Uniden unit, in turn setting them up to go on the Master Jack. Then once all going on the Master jack, then connect up the "Going away" wires, and then go to the next jack, (any) and plug in the unit, and test it, and so on. working towards the "End" BT Jack.
That should enable you to troubleshoot and understand whats going on.
Make sure they are fully charged, the Code is set according to the manual. It would also pay to download a user manual for your exact make and model.
