Cisco 1941 Router - CISCO1941-SEC/K9 Logo
G
GuoJames Posted on Jan 30, 2015
Can I have optical ports on CISCO1941?
Our office is using the CISCO1941 router, but our equipments require more bandwidth to connect. Can I have optical ports on CISCO1941?
stellahayes
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jan 30, 2015
stellahayes
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
1735
Points
34
Yes, but you will need to add interface card EHWIC 1GE SFP CU, in addition to the interface card, a SFP module will be required to make the optical ports working.
Can,t get net flex on tv. in settings it says the signal is excellent but it cannot connect to the internet. I can get net flix on the computer. I'm using a blue ray,modem,computer,and wireless netgear...
You may have to see if you get enough bandwidth....the more devices you have off your router the less internet each gets...also wifi connection is not as fast as a wired connection. Check to see your speeds, HD requires 4 times more bandwidth than regular videos.
tip
Popular Cisco 1900 Series Routers Including Cisco 1941/K9, Sepcial for Mother's...
Cisco 1900 router series including CISCO1941/K9, C1941-SEC-SRE/K9, CISCO1941-SEC/K9, CISCO1941W-A/K9, CISCO1941W-E/K9, etc. are designed for small office and small enterprise branch offices, delivering high-performance, highly secure connectivity with multiservice integration that can transform the workplace with a broad set of services, rich-media support, and operational excellence.
Key features of Cisco 1900 series in detials:High Perfomance: Cisco 1900 series routers offer significant performance improvements over previous-generation ISRs such as 1800 series.
Investment Protection: Cisco router 1900 Series reduces deployment costs and increases flexibility. The platform also offers investment protection with support for a majority of existing WICs and HWICs.
Services On-Demand: The Cisco 1900 Series Integrated Services Routers reduce total cost of ownership by decoupling the delivery of software from hardware on optional service modules. In addition, you receive a Universal IOS image capable of enabling all of Cisco's rich IOS features and allowing you to quickly deploy new services.
Energy Efficiency: The Cisco 1900 Series architecture incorporates higher-efficiency power supplies with intelligent power management.
Specifiction of Cisco Router 1900 series:* Embedded hardware-accelerated VPN encryption.* Secure collaborative communications with Group Encrypted Transport VPN, Dynamic Multipoint VPN, or Enhanced Easy VPN.* Integrated threat control using Cisco IOS Firewall, Cisco IOS Zone-Based Firewall, Cisco IOS IPS, and Cisco IOS Content Filtering.* Identity management that uses authentication, authorization, and accounting (AAA), and public key infrastructure.* 2 Integrated 10/100/1000 Ethernet ports.* 2 enhanced High-Speed WAN Interface Card slots that can host 2 single wide or 1 double wide and 1 single wide (e)HWIC.* Fully integrated power distribution to modules supporting 802.3af Power over Ethernet (PoE) and Cisco Enhanced PoE.
Overall, Cisco 1900 Series Routers offer unparalleled total cost of ownership savings and network agility through the intelligent integration of security, wireless, and application services.
After knowing more information about Cisco router 1900 series, it's nice choice for you to select one of Cisco 1900 series that meet yor need in net to net.Why not choose? More tips about Cisco products and other Cisco network equipments you can visit here: http://www.router-switch.com/Price-cisco-routers-cisco-router-1900-series_c16
on May 05, 2011 • Computers & Internet
When my daughter uses her ipod wi fi my internet speed drops
Setting the QOS priorities enables the wireless router administrator to control bandwidth traffic by setting certain ports or device MAC addresses to high priority and others to normal or low priority. These settings will give high priority devices and ports first access to bandwidth, while limiting bandwidth for the lower priority devices and ports.
I have 10 computers and 2 printers networked in the office. I'd like to hae them all wired. I bought a 10/100 switch but not sure how to hook it up with my router. Any advice?
Most low to mid range switches require no configuration. Switch-to-router connections use a standard straight-through CAT-5 network cable, same as for your PC. Connect any switch port to any LAN port on the router (you didn't say if your router has more than one) and then connect your PCs and printers to the other switch ports with CAT-5 network cables. The WAN port on the router remains connected to the upstream (Internet) provider.
I have tried a 'spare' LAN connection in the office but my pc will not connect to the network. Does the port require activating?
The port shouldn't need 'Activated'. If you are trying to connect using a 'spare' port in the wall, the wall socket may need 'patched' in to the network to allow your computer to communicate through it.
If you are connecting directly to the router/switch/network hub, it may possibly be an upload port you've connected to (a port used to connect one hub to another or to the main network). There is sometimes a switch next to the port to change it to a normal port, alternatively try selecting a different port to see if your computer will connect.
Amber lights on a Cisco switch.
It sounds like you have loops in your topology. Loops will cause the LAN to crawl.
Amber, on a Cisco switch port means that a port has been blocked either as a security violation (if mac-address security is being used) or by spanning-tree protocol which shuts down ports involved in a network loop.
Check all your wiring carefully...especially the fiber-to-ethernet converters. If anybody has a hub or switch under their desk make sure they do not have two ports from that device patched into two ports in your cisco switch.
From Cisco catalyst 3500 user guide:
Solid amber
Port is not forwarding. Port was disabled by management or an address violation or blocked by Spanning-Tree Protocol (STP).
Note After a port is reconfigured, the port status LED can remain amber for up to 30 seconds as STP checks the switch for possible loops.
2answers
LimeWire
If the firewall is turned on you router you will have to turn off the ports that LimeWire uses.
Suggest config of DI 524
Are you using a DHCP server for boths sites A & B, or just using static IP addresses for all the PC's ? What is your IP scheme ? Are you using this D Liers just to connect sitenk routers just to connect sites A & B? Sorry for all these questions, I am trying to picture your network before attempting a solution for your needs.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
