Some discs don't work in some recorders. I always use verbatim, ritek or tdk discs and have very few problems. if the recorder suddenly dislikes a batch of one brand, I'll use one of the others.
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
SOURCE: go video vr3840 dvd/vcr player recorder combo
HELLO. IT SOUND'S LIKE YOU NEED TO CLEAN YOU RECORD & YOUR PLAYER TO ME . "GOOD LUCK"
SOURCE: won't accept disks (any kind)
try universal dics for you dvd.maybe it is not compatible with your player...
SOURCE: Unit does not recognize DVD-R and is ejected from the player
You may need to try a DVD+R disc. Some of the players/recorders are REALLY picky.
SOURCE: we have a govideo vr2940
I've had this problem (No disc) with my VR2940 and was preparing to open it up and find and clean the lens that detects the disc. This was suggested as a solution.
However, I used a can of compressed air (enviro-duster) and sprayed air in the drive slot (back and forth since I don't know where the lens is located).
No problem since, but I keep a can handy.
Norm
