How to Hack Your Forgotten Password in Windows 7?
<span>For convenience, we often create an easy-to-remember and uncomplicated password for the PC like birthday date, which makes great possible to<span> </span><b><a href="http://blog.passwordunlocker.com/how-to-hack-window-password-in-windows-7/">hack Windows 7 password</a></b><span> </span>by guessing. So, how to prevent from your Windows password being hacked?<br />Following is the tip and trick that tells you to hold back hackers' access into your laptop with the guessing password.<br />
Enable Account Lockout if one tries to guess your password
<p>Regarding your worries that someone tries to hack Windows 7 password by guessing it, you can simply in case of this by enabling Account lockout in Windows 7.<br />
<ul>
<li><b>Step 1.</b><span> </span>Open Local Security Policy windows by inputting open local security policy in the Start search box and hitting Enter.</li>
<li><b>Step 2.</b><span> </span>Double-click<span> </span><b>Account Policies on the left and select<span> </span><b>Account Lockout Policy</b>.</b></li>
<p>You'll find that there are only three policies in the right hand pane, and your account should not automatically lock out when the password is entered incorrectly by default.<br />
<li><b>Step 3.</b><span> </span>Right-click the<span> </span><b>Account lockout threshold Policy</b><span> </span>and select<span> </span><b>Properties</b>.</li>
<li><b>Step 4.</b><span> </span>Set the number of login attempts that you want Windows to allow before it locks the account when the properties window comes up, and then click<span> </span><b>OK</b><span> </span>to save settings.</li>
<li><b>Step 5.</b><span> </span>Windows will prompt you to set suggested settings for Account lockout duration and the length of time to Reset account lockout counter. We usually use the default values of 30 minutes by clicking OK. You can also modify the values according to your needs.</li>Your Windows 7 user account will lock after the set number of failed login attempts. With the settings in this case, you account will be locked for 30 minutes if the password is entered incorrectly 5 times in a row.<br />The Account Lockout Threshold is a security setting that determines the number of failed login attempts before that account is locked out.<br /></ul>But sometimes you may still feel worried as your password is too "strong" that you would easily forgot Windows password by accident. Therefore, you have to find way to hack Windows 7 password. If you have the similar troubles, you can take the following tip for reference.<br />
Hack Windows 7 password with Windows Password CrackerAlthough there are many options that can<span> </span><b>hack Windows 7 password</b>, in my opinion, the best and effective is to get a Windows password crack, like<span> </span><b>Windows Password Unlocker</b>. Why? Looking upon the questions about Windows 7 password hack I meet, few askers can access the computer with another administrator account or create a password reset disk in advance to in case of a forgotten Windows password.<br /><b>Windows Password Unlocker</b><span> </span>and other crackers allow you to crack Windows 7 password by burning a password recovery disk with a CD/DVD or USB flash drive in a few minutes, no matter the length and complexity of the lost password. Never requires previous password and special compute skill: Never needs to reinstall computer and no data lose after Windows 7 password hacks.<br />Only 4 simple steps as follows.<br /><img src="sta-reset-button.jpg" />
<ul>
<li><b>Step 1.</b><span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Download Windows Password Unlocker Professional</a></b><span> </span>from any available computer and install it.</li>
<li><b>Step 2.</b><span> </span>Burn a password recovery disk with USB flash drive</li>Insert your USB flash drive in the computer and run the application. Next what you need to do is to burn a password recovery disk with the USB flash drive via the application.
<li><b>Step 3.</b><span> </span>Set your locked PC to boot from USB</li>When the password recovery USB disk is burned, you should plug it in your locked computer. Boot your computer and set USB as the 1st boot device.
<li><b>Step 4.</b><span> </span>Hack the forgotten Windows 7 password</li></ul>The interface of Windows Password Unlocker Professional will appear when you boot from USB. And you'll find all Windows 7user names of your accounts will be displayed with the passwords showing unknown or empty. Now you can select the target Windows 7 account and start to hack its password within a few seconds.<br />Ok, now you have sucessfully finished to reset Windows 7 password with this special utility.<br />After the tips and trick s listed above, are you still afraid of your Windows 7 password being hacked or can not access into the comp if<span> </span><a href="http://www.passwordunlocker.com/knowledge/forgot-windows-7-password.html"><b>forgot Windows 7 password</b></a>?<br /></span><br />
