NAnte Salas Posted on Jan 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konzert amplifier av 302 theres an echo sound even I can change all new all the IC and variable resistor on the mic amp all so the capacitor besides at the echo sound but if I can turn off the echo it worked but not good because theres no echo. how can i fix this problem?
  • NAnte Salas
    NAnte Salas Jan 30, 2015
    that is not used in the car sir that i used in our home please see my attached picture..
Daryl Gleaton
Level 3:
  • Master 749 Answers
  • Posted on Jan 29, 2015
Daryl Gleaton
Master
Level 3:
Answers
749
Questions
0
Helped
234615
Points
2170
Check the ignition coil, they will often heat up and then produce no spark. Are there any codes present? Is the check engine light on?
  • NAnte Salas
    goog am sir my amplifier was i used in our home not in the car, please see my attached picture thank you for your responds.
  • Daryl Gleaton Feb 04, 2015
    I don"t know how this happend but this is an answer for a Jeep that was stalling out. The question had nothing to do with an amplifier. Guess fixya screwed up.
How do i fix my konzert amp after i change the ic
What is the problem? You can contact me at my website, audioserviceclinic.com. You can contact me there.
SIR,,i have konzert av 302 no sond but there is power please help thanks
There can many causes. You may have an amplifier damaged, power supply issue, on and on. If you are interested in having your Konzert repaired, please visit my website at audioserviceclinic.com. You may contact me there.
3answers
I have a konzert av 302, i am wondering why it's sound is echoing even if the echo volume is off. can anyone help me please?
A faulty volume potentiometer? Some internal cross-talk? Free wires induction because they are too close, inside? It sounds possible to me and a minor problem. Don't worry too much.
200 watts is the output, home use or commercial? not a good amp to run at its max as it has a low reserve headroom. for home use 100 watts rms is more than enough.
Konzert amplifier av 302 can i use 4pcs of 200watts speaker in that amp
It depends on the impedance of the speakers, if you use (2) 8 ohms speaker on each channel the load will be 4 ohms if you use (2) 4 ohms the load will be 2 ohms , check and see what load the amp can handle.
1helpful
KONZERT AV-502A KARAOKE AMPLIFIER,POOR AUDIO,2-RESISTOR WORN OUT PLS. HELP ME
pls check burnt resistors, if ceramic it's value is .25 0hms 5 watts, if big carbon film resistor it's value is 10 ohms 3 watts. check also power transistors A1941 & C5198. also check driver transistor A940 & C2073
I have a konzert 302, just the other day I was wondering why the left speaker sound is disorted and very scratchy. I Thought it was only my speakers but I check and found out it was from the left chan
If you intend to DIY , check for possible cold solder joints,
leaky transistors , changed-value resistor.
Upgrade to 502 it is better than the one you have.
6helpful
3answers
How can i upgrade my av 302 to becomes best as konzert av-502
upgrade your 302 to 502 need to replaced the toroid transformer, set of output amplifier, set of electrolytic capacitor.
Purchasing of these parts one-by-one is much expensive rather that you buy a brad new Konzert AV-502. Also upgrading the unit is quite tech and need a lot of experienced in electronics.
Hope that it may help you.
Have a nice day.
JDVillanueva
 Grubhead
Grubhead
SmartAviator
SmartAviator
