Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Seagate freedesktop agent 500gb, not detected on windows xp
I recently purchased a Seagate freedesktop agentof 500gb capacity.IT always had problems with detection with windows.It got detected for teh ist week .But had issue with delay write failures.Now it is no detecting at all.the lights come normally but it never gets detected on windows.i tried so many steps.but no go. Could u advice any resolution.Iam using Win xp pro with sp2.
Re: Seagate freedesktop agent 500gb, not detected on...
My wife had the same problem when she tried to install it. When ever you install software direct from the harddware itself and has trial offers bult in it. It is always monitoring your time and date and validating. So you have to uninstall from add remove programs from all 3 programs from seagate and check your registry for unremoved protocalls. Good Luck!
Posted on Dec 28, 2008
I am facing the same same problem with my freeagent 750. It work some time, but most of the time it shows u in My Computer, but cannot enter. Couple of time if you run "chkdsk <Drive Letter>:/R" re-scans the entire hard disk and then it shows up. But that too stopped working now :-) Still hanging around for a resolution.
Posted on Dec 12, 2007
0 characters
3 Points
Hello Sir i purchased 500 GB seagate 500GB free agent go hard disk 2 years before. recently i encountered the problems as follows. usb did not recognize the hard disk and it sound like sparking also white...
What sounds like sparking could be a head crash. If it is a head crash
then you are basically finished with the drive. They all go sometime.
The only safe way is to have another backup drive and keep a current second
copy of all information which you must save. Even this procedure is not
completely safe.
The hard drive should not make any noticeable sound (not more than a fan
sound). If it does, then it is probably dead or about to die. If the information
on the drive is IMPORTANT, then you can contact a data disc recovery site
which can help you with removing most of the data from a crashed disc.
I pioneered this recovery system idea many years ago and several companies
exist now to recover data from crashed discs.
Aug 29, 2011 | Seagate FreeAgent GO Portable, 500GB...
My Seagate 500GB not detected in Windows 7. Fine in Windows XP
hi there,
how old is your hdd? it could be that your hdd did not come with support for windows 7. if that is the case, you will need to log onto the seagate website and download the latest software/driver for your hdd. hope this helps :)
Jan 18, 2011 | Seagate Hard Drives
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a Seagate Free Agent Pro GB HD. Recently purchased a a new computer and cannot locate drivers for this equipment, can you recommend a site where I can download?
Hi and Welcome to Fixya,
Here is the download site from Seagate
Please check that link and then download the driver for your device.
Jan 12, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to partion seagate Free Agent Pro in Windows XP
First make sure that you have a bootable Windows Vista installation DVD, as you will be unable to use your computer if you don’t. Next, download the GParted Live CD and burn it to cd.
Boot off the GParted cd, and you will see your hard drives in the drop-down list. The first drive is typically your boot drive, but you can check the Flags column to make sure.
Next you’ll need to right-click on the partition and choose Resize/Move from the menu.
Now you can either use the New Size textbox, or just click and drag the partition to make it smaller (or bigger). When you are done, click the Resize/Move button.This doesn’t immediately apply the changes, though. You can make other changes to your partitions and then when you are finished click the Apply button.Depending on the amount of data and the speed of your computer, it can take quite a while to resize the partitions. On my computer it took more than 30 minutes.
Once it’s done, quit, remove the live cd and then reboot your computer. Unless you are very lucky, you’ll be greeted with this horrible error message saying “Windows Failed to start. A recent hardware or software change might be the cause.”
Hope this helps!
Sep 07, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I havea seagate 500gb external hard disk, when i connect it wth the laptop the hard disk is not recognised on my laptop. i have windows xp professional installled in my laptop
Click on the link below and then click on the "Fixit" button. Windows has a patch for all external devices not recognized by PC's including HD's. This is especially an issue for those who've recently installed SP3. Best of luck with your problem.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Does Seagate Free Agent 1TB support Windows 2003 Server
Go to Computer Management. (compmgmt.msc) then to Disk Management and assign drive letters .
u will c ur disk.
Jun 19, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
1,052 people viewed this question
Top Seagate Hard Drives Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a Seagate Hard Drive Expert? Answer questions, earn points and help others
