1. My ideapad Y430 easy cam doesnot working after i reinstall windows vista ultimate. Not i cant use it for my password. 2. I also try to partition it into four but it doesnot support i can have only two...
this is all I can offer in your situation.....one option is to..use the...
Novo button
This button functions as a reset button; use with caution. Press the
1. Novo button to enter the main interface of OneKey Recovery while the
power is off. You can use OneKey Recovery to restore the primary
hard disk partition (usually drive C) back to the factory default
configuration, including the operating system and the software on it.
Attention: Once done, the system can no longer return to its previous
state. All data on the primary hard disk partition (usually
drive C) will subsequently be lost. So make sure all
important files on the primary hard disk partition have
been backed up onto another hard disk or USB hard disk
drive before this operation.
For details, see “OneKey Recovery4.65 User Guide
2. For the camera check out these key functions....
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
3. And for the password...here you go....
Using Passwords
Using passwords helps prevent your computer from being used by others.
Once you set a password and enable it, a prompt appears on the screen each time you power on the computer. Enter your password at the prompt. You cannot use the computer unless you type the correct password.
Make sure that only authorized individuals access your computer.
Establishing different kinds of passwords requires that other possible users know the proper passwords in order to access your computer or your data.
As many as three passwords might be needed for your computer: the Supervisor password, the User Password, and the hard-disk drive (HDD) password. When the Supervisor password is set, only the Supervisor password entitles you full control of the computer.
• User password
If a user password is set and Password on boot is enabled, a password prompt appears when you turn on the computer. Unauthorized users cannot get access to configuration data.
You can also use the user password to enter the BIOS Setup Utility, but once the Supervisor password is set only a part of the options can be set.
• Supervisor password
With a Supervisor password, you can get full control of the computer. It also can be used as a power-on password, the same as the User password. Also, when you enter the BIOS Setup Utility with a Supervisor password, you are entitled to set all of the options.
• Hard disk (HDD) passwords
Once an HDD password is set, you need to enter it to get access to the hard disk. You can set the HDD password through either the User Only selection or the User + Master selection in the BIOS Setup Utility.
Note: If you set passwords through the BIOS Setup Utility and you put your computer into sleep mode by pressing Fn + F1, the following describes the behavior of the computer when you bring it out of sleep mode:
• You are prompted to type the Windows log-on password rather
than the User password to resume operation.
• If an HDD password is assigned to any hard disk drive, the hard
disk drive is unlocked automatically when you resume operation.
To set a User Password:
1. Turn on your computer. Press F2, while the initial screen is displayed.
The BIOS Setup Utility screen opens.
2. Select Security, using the cursor directional keys.
3. Select Set User Password, and press the Enter key. The Set User Password window opens.
4. Choose your user password, which can be from one to eight
alphanumeric characters in any combination. Type it in the Enter New Password field.
5. Press the Enter key once to move to the Confirm New Password field. Retype the password you just entered to verify it.
6. Commit your password to memory, and press the Enter key.
7. Press F10 to exit.
8. Select Yes in the Setup Confirmation window.
Changing or Removing the User Password
To change the password, do the following:
1. In the Enter Current Password field, type your current password.
2. In the Enter New Password field, type a new password; then retype it to verify.
To remove the password, do the following:
2. Leave the Enter New Password field blank, and then press the Enter key twice.
Note: Make sure the Password on boot is set to Enabled if you need the password protection at power on.
To set a Supervisor Password:
Only a system administrator will be able to perform this procedure.
2. Select Security using the cursor directional keys.
3. Select Set Supervisor Password, and press the Enter key. The Set Supervisor Password window opens.
4. Choose your supervisor password; it can be from one to eight
5. Press the Enter key to move to the Confirm New Password field.
Attention: You might want to note your password and keep it in a
safe place. If you forget your supervisor password,
Lenovo can not reset your password. You must take your
computer to a Lenovo reseller or a Lenovo marketing
representative to solve this problem. Proof of purchase is
required, and a fee will be charged for parts and service.
The next time you open the BIOS Setup Utility program, you will be prompted to type your password to proceed.
Changing or Removing the Supervisor Password
1. In the Enter Current Password field, type the current supervisor
password.
2. In the Enter New Password field, type the new supervisor password; then retype it to verify.
password.
Hard Disk Passwords
Two types of the hard disk passwords help protect the information stored on the hard disk:
• Hard disk user password
• Hard disk master password, which requires a hard disk user password If User only is selected and a hard disk user password has been set, but no hard disk master password has been set, the user must enter the hard disk user password in order to gain access to files and applications on the hard disk.
If User + Master is selected you need to set a master password and a user password both as the Hard Disk Password. Either of the two passwords can be used to get access to the Hard disk. Any change or removal to the master password deletes the user password.
To set a hard disk password:
Print these instructions.
3. Select Built-in HDD1 Password Select, and press the Enter key. A window for selecting User Only or User + Master opens.
I will send the rest in the comment section..hope this helps in some way...the Fang.
