Home | Danby | DDR586R Dehumidifier - 58 Pints Dehumidifier | Help! Water keeps fil...
Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Problem for Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Help! Water keeps filling the tank instead of going out the hose
By oskarf on Jul 07, 2009
I like my new Danby dehumidifier 410A and it pulls lots of water out of the air, but about every other week it starts filling the tank, which is a huge problem, as I am not easily able to go up and down my basement stairs. I have the hose hooked up properly, as far as I can tell. It hangs vertically down from the place where it is hooked up. I am about to go on vacation and I need this hose to work consistently! HELP!!!!!!
Best Solution
posted on Jul 24, 2009
Very Helpful)
handscc
Rank: Apprentice
Rating: 100%, 1 votes
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 07, 2009
Somewhat Helpful)
adirondacktr
Rank: Guru
Rating: 85%, 237 votes
bacteria build up in tank and sludge empty tank and pour in several cups of bleach should fix problem after hour
Was this helpful?
Yes
No
Popular Solutions for Danby DDR586R Dehumidifier -
Questions and Unsolved Problems for Danby DDR586R Dehumidifier -
Do you recommend Danby DDR586R Dehumidifier - 58 Pints Dehumidifier?
Answer
Answer
i recently had a brown-out and have had damage to a number of appliances. this occurrance blew the... (More)
Answer
how could i use my ddr586r dehumidifier because i lost my instraction
Answer
Danby Dehumidifier Model # DDR586R Serial # 6763858666 (only 28 months old) - Does not collect water... (More)
Answer
tank does not fill with water at all. How to adjust humidty levels? what does the temp grad mean?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR586R Dehumidifier -...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
