Dear,
You cannot get reliable unlocking codes
for BlackBerry for free because free codes can lead to several technical
problems. I would suggest you try a reliable and decent unlocking code vendor
that provides cheap and trusted codes for mobiles.
You can unlock your Blackberry from Blackberry unlocking Codes with MEP. I am pasting their direct
link HERE that would guide you to
the page where you order your code. See for yourself like I did personally.
I am a regular customer of this vendor now and fully satisfied with what I have
been given. goodluck!
Here you will get the MEP number of your Blackberry phone
Instructions for obtaining MEP number
See The website below for a solution
http://www.unlockingarena.com
There are 2 ways you can read the mep code of a Blackberry phone one is by cable and the other is using the keypad however you need need to unlock a secret menu. All the information and step by step guides are found here.
http://www.unlockingblackberry.co.uk/ins...
I need the mep code to unlock my blackbery curve 9300
SOURCE: can't connect Blackberry Curve 8320 to 2wire wifi
W002 - Wi-Fi Connection Failed
Means The phone cannot get an IP Address from the Server.
Common issues are
The signal is to weak to make a reliable connection
WEP is configured incorrectly or WPA
DHCP may be disabled, it needs to be enabled on the router
There are other more technical issues to this but without more information this should be a good start.
SOURCE: unlock
Hai,
U may visit the website unlockzone.From this site U can get the unlock code for your mobile.
SOURCE: need mep code to unlock
To unlock blackberry curve 8320 network you will need a reliable blackberry unlock code, mep code can't unlock your phone. That unlock code can be purchased at third parties sites on internet.
No one can give you unlock code for free. and dont try to enter unlock code. because it will block your blackberry. if you want to unlock your blackberry only use trusted sites. order your Blackberry 8520 curve unlock code herehttp://blackberrymep.com/unlock-blackber... this site charge very reasonable price.
