Question about Patton PUH680-U Utility Heater
Patton space Heater Model # prh-5
My space heater will come on and then go off in about 15 seconds and then it will not come back on. the caution light comes on. Can you tell me what is wrong with it?
  • 1 more comment
  • Anonymous Jan 03, 2008
  • jdean75 Nov 19, 2008
  • Clark with Big Toast Dec 11, 2012
    MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
Check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
Posted on Dec 22, 2008
Patton space heater power knob isn't working
First thing check see if you have power going to switch with a multimeter if you have one if there's power going in it switch need new switch probly you can us your multimeter to test switch on ohms
Mar 01, 2013 | Heating & Cooling
Will the patton electric heater significantly raise my electric bill
1500 watts is 1.5 kilowatts. Run it for 1 hour and you have 1.5 kilowatt hours. My electricity costs .08 per kilowatt hour so, when I run my 1500 watt space heater, it costs me a whopping .12 per hour to operate. I can afford 12 cents per hour, compared to oil at $3.50 per gallon and a burner that burns up to 3 gallons per hour.
Dec 23, 2012 | Patton Electric Patton PUH680-U Electric...
I purchased the Patton PUH9000 heater last year. I puts out a lot of heat at first, but shuts itself off after about 5 minutes, then cycles back on after a couple of minutes. Is this normal operation? I...
These have poor quality safety parts that fail in about 1 season or less, the failure rate for these little cheaper units is high, go Honeywell next time!
Jan 11, 2011 | Patton PUH9000-U Heater
My Patton PUH680 space heater is not working. Do you offer replacement coils?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Dec 06, 2010 | Patton PUH680-U Utility Heater
I need the lighted switch on front of Patton milkhouse space heater model puh680-u but can't track down web sight to order.
May 22, 2010 | Patton PUH680-U Utility Heater
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Apr 01, 2009 | Patton Electric Patton PUH680-U Electric...
The Caution Light ?
Nov 30, 2007 | Patton PUH9000-U Heater
Space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
Mar 28, 2007 | Patton PUH9000-U Heater
Patton PUH680-U Utility Heater Logo
985 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
ray gallant
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
