Question about Ricoh Aficio Mpc2800 Digital Color Copy Print Scan
Double image on ricoh mpc 2800
Whats a problem
Posted on Jul 11, 2019
    Problem Solver:
  • 14 Answers
Make sure that the printer is set properly for the weight of the paper. If it is 28 pound laser color paper, set it up for middle thick, etc., in (User Tools / System Settings / Tray Paper Settings). It will run the machine slower, so the toner will more fully melt and adhere to your paper.
Posted on Jan 30, 2015
  • odenigbo Ifeanyi Aug 14, 2016
    i guess this is old add. But the problem is dirt on TD sensor. Clean it and run line position SP 2111, execute C, A and B respectively you should be fine
SOURCE:
When copying i have a shadow in background
Check copy life of consumables like Developer and Drum if ghost image might be Cleaning Blade found Imagaing Unit or Upper Fuser at Fusing Unit. If replace the whole imaging unit can solve your problem but individual parts try to clean first imaging include charge roller before you replace drum, cleaning blade and developer. mostly we replace developer only.
Mar 06, 2015 | Ricoh Aficio 1013 All-In-One Laser Printer
Have a bizhub c550 printer and when printing a plain white document i get a yellow background, What could be the problem?
Sir/Mam, have you replaced the yellow image unit ? Not the yellow toner cartridge. There two seperate units. Also there are on each image unit blue/white nubs that you can pull out and push back in to clean interal image unit parts do that you do not have to pull the image units out just ensure that when done cleaning they are pushed all the way back in. Once the image units are not toner cartridge and there are four of them located below each toner cartridge .
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 08, 2015 | Konica Minolta Bizhub C550
I have a problem with a bizhub C203 what can i do?
Verify the problem is in the imaging units or the transfer belt units.Remove the transfer unit and clean on vacuum cleaner the transfer belt cleaning blade.If you see the stripes on transfer belt after cleaning is work normally.If not observ stripes on transfer belt the problem is located in imaging unit.Enter in service mode :Press Utility key-Meter count- Details-Stop 00-Stop01 Select Test mode-select Gradation test pattern and select the Cyan press Start,after select Magenta Press Start,Yellow +Start,Black4+Start.If any color test pattern is not graduate the problem located to image unit when is not graduaTE.
Jul 28, 2014 | Konica Minolta bizhub Office Equipment &...
Ineo +200 status p 6 and p 21
P-6 : Cyan imaging unit failure
P - 7:Magenta imaging failure
P -8 :Yellow imaging unit failure
P -9:Black imaging unit failure
Select Imaging Process adjustment - D Max Density and if the setting value is negative readjust.
Check the drive transmission portion of the imaging unit and correct as necessary,clean theIDC registration sensor windows if dirty,clean the contact of the imaging unit connector if dirty,check the high voltage connector for proper connection.If necessary change the image unit or the image transfer belt unit.
P -21 : Color shift test pattern failure.
Wipe clean the surface of the transfer belt with a soft cloth or change the image transfer belt unit if the transfer belt is damaged.
Feb 21, 2013 | Konica Minolta Office Equipment & Supplies
P-27
P - 26 1st image transfer ATVC black failure
P - 27 2nd image transfer ATVC failure
P - 29 1 st image transfer ATVC colour failure
Check the transfer belt unit contact and that of high voltage board for connection and clean or correct the contact.
Change the image transfer belt unit.
Clean the sensor windows on the transfer belt unit.
Feb 10, 2013 | Konica Minolta bizhub C450P Laser Printer
I have a Image Runner C3200 and it is tinting the paper black when making copies
- clean the laser units glass with the special cleaning tool provided with the copier
- check and clean the image transfer belt blade and the recycle mechanism
- check if the tinting is on the imaging unit , if yes change unit if not chevk above
Jul 27, 2012 | Canon imageRUNNER C3220 Color Copier
We have a lexmark 544 and i have changed the imaging kit and it says we have a defective imaging kit
Please try to do the following steps
1. Reseat all cartridges and Imaging Basket.
2. Remove Imaging Unit. To see the complete instructions on how to remove/replace the Imaging Unit, click this link http://bit.ly/jhK9fF
3. Clean the HVPS and POGO pins and the corresponding electrical contact on the Imaging Unit with a clean, dry cloth. Click link http://bit.ly/qxU9mD to see the POGO pins location.
4. Replace all cartridges and Image Basket (you need to send bad cartridges back).
If issue not resolve, contact Lexmark Technical Support
Feb 09, 2011 | Lexmark X544dn All-In-One Laser Printer
The screen says digital imaging kit is defective 31.06
Feb 03, 2011 | Lexmark X544dn All-In-One Laser Printer
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
I cleaned the toner of my coper machine and when i
Might want to get a new image unit. Did you recently replace the image unit. Did you use a vacuum cleaner to clean toner??? . (DO NOT USE A VACUUM CLEANER TO CLEAN TONER STATIC ELECTRICTY CAN DESTROY THE SENSOR UNDER the Image unit.
Try this site and get new image unit if available you have legacy Minolta machine.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Oct 30, 2009 | Minolta DiALTA Di250 All-In-One Laser...
Ricoh Aficio Mpc2800 Digital Color Copy Print Scan Logo
804 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
