Question about SanDisk Sansa e250 MP3 Player
Sansa e250 using micro sd card
My sansa e250 recognizes my micro sd chip and how much space is presently being used but it wont recognize the songs on it. my windows media player will show me whats on my sd chip but the sansa e250 wont. it onlt tells me how much space is being used.
Re: sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Posted on Dec 19, 2008
If you are seeing the "Bad Track" window pop up on your player when you try to play the song, the file has become corrupt. If it just does not show the songs at all on the screen try these step, you could try putting the songs on again, this must me done with the card in the player, in MSC mode, and synced with windows media player. When in media player under the sync tab, you will see two sansa items (one ususally says removeable disk "drive name", click that one and sync your music to it. The drag and drop method works, but with a higher rate to corrupt your music. Make sure you have windows media player 11 aswell. Also, when the card is in the player, while it is on, don't mess around with it, (ie. pull it out). I have found that if you put the card in after the player is on it doesn't always refresh the database properly. and finally, make sure you format the card incase it is corrupt, because it will show how much space is being used, but can't be used to store media/play it.
As for the video, as far as I know you can't play video's off of your SD card, only music and photo's.
Posted on Oct 17, 2008
I had the same problem where I would connect my Sanse e250 to my PC and Windows would only recognize the player, not the Micro SD card. I fixed this by switching Modes on the Player from PlaysForSure to Rhapsody. My PC will now recognize both the player and the micro SD card.
Posted on Jun 20, 2008
When i connect my sansa with the computer everything is alright, but i can't put anything on my micro SD card, because there is no sign for it.... ??
Posted on Jun 06, 2008
After trasfering songs to micro sd iam not able to see songs in player.can you fine way to how to accesssongs.
Posted on Mar 08, 2008
  • 155 Answers
Change the mode of the player to MSC and connected the player to the computer, this will help detect the microsd as a removable disc drive.Transferring songs to the card is via drag and drop or copy and paste.
Posted on Dec 08, 2007
0 characters
3 Points
2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
Aug 27, 2009 | SanDisk Sansa Fuze MP3 Player
When I put a 2 GB micro chip in my sansa e250, all I had to do was update my sansa for it to recognize the chip. I just switched to an 8 GB micro chip and my sansa and computer wont recognize it. I did the...
i think you put it back again your 2GB micro chip, its not necessarily to put 8GB, it will not work.. Your sansa e250 is design for 2GB only, your not an inventor to do that... your only a user, if you something stupid on that, its your own risk but for me its not necessary, your not contented with that.. All you have to do buy a new one which a lot more than 2GB and up, right!... Don't be so pathetic to do that things, even the company don't want really to change even the micro chip inside.. They were not selling for that kind of MP3 player... if might be then they will loss profit on their product, youve been pirate on it... hope you understand the situation...
Jul 08, 2009 | SanDisk Sansa e250 MP3 Player
Sansa c240 and a 4 GB Micro SD HC card.
Sansa C240 can only read SD cards that are NOT SDHC - that means it can only read up to a 2gb Micros SD card.
Jun 05, 2009 | SanDisk Sansa c240 MP3 Player
My sansa player does not recognize a micro sd when its inserted
Sorry, it doesn't work that way. You can use a separate card reader to put files onto the microSD card. When the card is installed into the Sansa, the Sansa will see the additional music.
Feb 03, 2009 | SanDisk Sansa e250 MP3 Player
Does not recognize the micro sd card
First, make sure it's a microSD card and not a microSDHC card. If it's larger than 2GB then it's a microSDHC card and won't work. Second, make sure all your music is in a folder named "MUSIC".
Jan 20, 2009 | SanDisk Sansa e250 MP3 Player
How to access SD micro card on sansa e250
I expected to find the new playlists on the SD card as a separate file to access and play. Instead the SD card songs show on up the Sansa menu simply added among the existing songs / artists stored in the Sansa. Its not a solution but they are there. Since using the SD card, my Sansa does databse refresh everytime it starts, whether SD card is in it or not.
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
Micro sd card
Does your computer has an internal card reader?
Aug 14, 2008 | SanDisk Sansa E280 MP3 Player
Micro SD card is no longer recognized
make sure the card is 1 gb or less - a Sandisk card would be best since it's a Sandisk player
Jul 26, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 Player not reading SD 1GB Card
The Sansa is unfortunatley one huge mess up the programming has failed its working on a database with only 4 levels but for grphics and songs you need at least 7 lhopefully you can return it and get another if not you can try putting another type of chip hopefully that will work
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
Micro sd 4gb card problems.
Check the Sansa tutorials at
to make sure you have followed all the steps first.
In my experience, every mp3 player/photo frame/etc with a card reader has a MAXIMUM memory limit for the type of card that it can read. It is possible that the Sansa player can only read 2GB Micro SD cards or smaller - and thisi nformation may not have been available when they printed the manual. If you have followed all instructions, and it still will not read the card, try switching to a 2GB Micro SD card.
Mar 22, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
3,500 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
