Question about Rinnai Desa Vent-Free Infrared Gas Heater: Vent-Free Infrared Gas Heater(18,000 BTU)
Vent free infared heater
Brand new last season my LP vent free IR heater worked perfectly. This season, the far right heater plaque glows for a short while then it starts "popping" steady, it doen't glow and a blue flame can be seen on the front side of the plaque. The other 3 plaques work perfectly. I used low pressure compressed air and blew out the area, no change.
Any suggestions
  • 1,420 Answers
What you are experiencing is common if the plaques are either out of alignment or the burner is dirty. I know you said you cleaned it with low pressure air, but you need at least 120 PS. of air to clean the burner and plaques as per the owners manual.
Posted on Nov 15, 2007
I have a GloWarm propane/lp gas space heater. Can I use bottled propane tanks?
no you can't, and aren't you worried about carbon monoxide poisoning? Where does the burnt air go?
GloWarm Heaters - ventfree infrared heaters
GloWarm Infrared heaters are residential gas space heaters that are ventfree,
so no venting is required
GloWarm Plaque Infrared heaters direct heat from radiant plaques that
"warm like the sun."
Infrared heaters heat objects in the room before the air,
making them ideal for un-insulated rooms in your home.
All propane heaters require a 100 lb. tank or larger!
GloWarm Heaters ventfree infrared heaters
Oct 27, 2015 | Heating & Cooling
My glo warm plaq doesnt glow red but has flame.thanks
The plaque may be out of place or may need replacing, depending on the age of the heater.
Also, although you have flame, make sure you have flame at that plaque that's equal to the other plaques. If you don't the burner may simply need cleaning.
Feb 13, 2011 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Lp vent free gas log inserts pilot light wont light
Could need a new thermocouple, but...The orface needs to be cleaned most likely. As long as you have proper pressure and the valve is set properly, it sounds like a supply problem.
Call your gas company, they will service it for you. You would need to have specialized equipment in order to clean the orface properly without damaging it.
Good luck
-------PLEASE CLICK ON 4 THUMBS UP 4 ME-------
Apr 25, 2010 | Procom 10K BTU, Vent Free, 2 Plaque...
Have a vent free lp wall mounted heater.40 lp tank with regulater. pilot light will light but only the tip of pilot light is flame.there is a space between pilot light and tube where lp comes out. does not...
Too much gas pressure. Are you sure that this is a LP heater and not a Natural gas heater? Is the regulator you have rated under 1/2 pound pressure? Try to throttle down the shutoff on the tank to see if pilot gets better. If so, you have a pressure issue. Gas you adjust the pilot gas valve?
Jan 22, 2010 | Procom 10K BTU, Vent Free, 2 Plaque...
Rinnai Energysaver 1001FT, ignites, blows 5mins then shuts down.
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
Jul 07, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Infrared Heater - flaming thru plaque
I had this problem. From using the center brick most of the time, lots of dust bunnies build up in the gas chimney behind the brick.
Tie 2 pipe cleaners together with a small perpendicular circle at the top and carefully remove the dust bit by bit by twirling the cleaner.
The brick should fire like new if it is carefully cleaned out.
Jan 15, 2009 | Procom ML060HPA Heater
Infared burners with flame at the tops of them
This may mean that the plaques are cracked, if they are cracked you cannot repair them, you would just have to replace them. You can contact Master Parts they may be able to help you. You can contact them toll free at 800-446-1446. Thank you
Nov 10, 2008 | Procom ML300HGA Heater
Infared heater
When was the last time you cleaned the pilot? In your owners manual there is a cleaning procedure. If you can't find the manual, go to You may be able to download one from their site.
Dec 18, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
300 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
