Question about Coby Televison & Video
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
  • Iris Alaniz Feb 04, 2015
    Thank you kml39, this was the answer I was needing to get the DVDS player to work.
    Problem Solver:
  • 16 Answers
If you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Posted on Jan 28, 2015
SOURCE:
SOURCE: EMERSON DVD RECORDER MODEL EWR20V5
here's a link to the manual emersonaudiovideo.com/pdf/om/EWR20V5.pdf hope it helps
Posted on Feb 12, 2007
stonephoenix
  • 563 Answers
SOURCE: Universal Remote Control
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, Coby is a company whose electronics cannot be controlled by any remote other than the one that came with it. This means there is no code available for universal remotes. If you need a replacement remote (it will be identical to the one that came with the unit) please call our customer service number above. They will take your information and provide you with the procedure for ordering a part from Coby.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Posted on Feb 05, 2009
stonephoenix
  • 563 Answers
SOURCE: philips universal remote not working for my coby dvd 224
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Posted on Apr 17, 2009
SOURCE: hi i need the code fome my coby dvd player 224 for
You can usually look up your universal remote manufacturers' website, and they'll have a listing of all the codes for the remote.
Posted on Aug 18, 2010
SOURCE: Lights up screen, has sound, but no picture on the units screen!
has good sound--but no picture. the hookup cables are correctly installed
Posted on Feb 17, 2011
Coby DVD-224 screen scrolling up and down wont stop to see movie clearly
1. Take out DVD
2. Reset the unit (yellow sticker on top of unit) tells you how.
3. Make sure yellow video cable is plugged into Yellow port on unit and TV.
Feb 03, 2010 | Coby DVD-277
I can get composite video signal from coby dvd, but the component video shows no picture. Audio is OK. What could be the problem.
Are you using component video cables for the component outputs on your tv? Plugging composite cables into component output generally will produce poor if any video.
Also, check the back of your dvd player to see if you need to flip a switch to enable component video output. Good luck.
Aug 21, 2009 | Coby DVD-224 DVD Player
Cannot connect DVD Player to cable ready television
If your tv does not have the standard 3 plug video ports ( Yellow, White, Red ) then you will need an RF modulator to step in between the Direct TV box and the tv on the cable line.
RadioShack sells them as well as many other places. http://www.radioshack.com/product/index.jsp?productId=2103095
Jul 22, 2009 | Coby DVD-224 DVD Player
No longer plays color picture
Try the settings for "pal - ntsc - cvbs" video formats, if the tv and dvd aren't set the same, then this can cause the problem(usually with distortion to picture, depending on how it's mis-matched)
Jul 05, 2009 | Coby DVD-224 DVD Player
Can't program coby dvd 224 help
Shana, What are you really trying to do!!!! Do you understand what the jacks on the Coby DVD player are for?? Can you connect the Coby player directly to TV AUX inputs and play a DVD?
Is the satellite 'box' still connected to TV/Monitor using TV Tuner set to chann 3 or 4? Is the TV you
are trying to use have any or none of those YELLOW/RED/WHITE jacks on the back of it that you
have never plugged anything into them. Is the TV always set to Ch3, and is never changed to any
other Ch number??? Do you only change Ch up or down using the satellite "box" tuner? ALL these
questions and more must be answered by you before anyone can help you out. You must know your
own equiptment and its capabilities. The COBY Player will never be found by the satellite dish tuner.
comments or info send to lmistyrel @ aol.com
louie12fix @ fixya
Dec 26, 2008 | Coby DVD-224 DVD Player
No picture
I gave up on the cheap Coby unit and upgraded to a more expensive toshiba one.
Sep 07, 2008 | Coby DVD-224 DVD Player
Coby 224 Screen Slowly Fades to Dark and Back To Light
Usually if your getting it with the MENU then your connection is weak, are you going through a VCR or some other type of device besides directly to the tv? Try hooking unit directly to the tv. Besides that, its possible you could of messed with the settings, go to the menu, go to advanced and do a reset to make sure no settings were adjusted, the disk has to be out of the tray while you do the reset.
Jul 14, 2008 | Coby DVD-224 DVD Player
Coby-224 DVD
Reset back to default
make sure no disc is in the tray
press right on the remote 3 times
down arrow once time- right 3 times - down arrow once then press setup the enter.
Jan 15, 2008 | Coby DVD-224 DVD Player
Coby dvd-224 "loading"
If everything else seems to be functioning, try using your remote to reset the TV. There is a setting to switch the TV from being a TV to being a screen, or monitor, for the DVD player. What the button is labeled varies by manufacturer. It may be: TV/DVD, input, source, display, or something else. Display, for instance, displays the choice on the screen. Highlight and select DVD or perhaps the brand name of the DVD player.
This compliments of the Vancouver Radio Shack super geeks.
Oct 24, 2007 | Coby DVD-224 DVD Player
Remote
if coby is an independent company you are out of luck. Is coby made by a "master company"? (e.g. orion is made by emerson and their codes work for orion products)
Jun 23, 2007 | Coby DVD-224 DVD Player
Televison & Video Logo
88 people viewed this question
Top Coby Televison & Video Experts
Ekse
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
