Siemens gr40 120a
Its this is load sharing per module,if the module is defective can i insert another module,without configuration.
  • 2,427 Answers
Yeah you should be able to
Posted on Dec 30, 2007
When i download the hw conf. in the plc im151 pn/dp after that plc mode is in stop and all modules sf led glowing(group error) Please tell me the solution
Re-check your hardware configuration.Make sure you correctly configured each slot ast to the type of hardware that is there. Make sure your program is not calling for a function (block transfer etc) to a module that isn't there.
Mar 09, 2010 | Siemens ENERGY & AUTOMATION W0404MB1200CT...
Fujitsu Siemens Amilo Xi1546
first start by downgrading to windows xp,then only upgrade you ram to 1gb then go to control panel and uninstall all the unnessacary files.
windows vista is generally a very slow program because it uses alot of space,xp is going to improve your speed and also dont load office 2007,rather load office 2003 its smaller and faster.
Jul 06, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
Configure wrt54g2
IF you mean "File Sharing" as in your own network of PC's on your network, then all you need to do is turn off sharing option within windows. Your router will not set sharing your folders, drives, printers, etc.
Check your windows setting in "Networks", then "Sharing" and set the appropriate options for your needs.
Hope that helps.
RJ
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
192.168.1.254
255.255.255.0
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
Unlisted device in homenetwork
no just the IP address. you have to enable to share on both computers in order to share any files.
you can share the whole hard drive of just certain folder.
first, you need to configure both machine on the same subnet, rename the machine so you see what is what. (right click on the network place> properties. right click on Local Area Connection. select the TCP/IP and configure it).
NOTE: it will be easier, if you configure all your equipment on the same subnet. (like: 192.168.168 200-10/255.255.255.0)
2). control panel> system> computer name, configure that (both machine need to be in the same group).
3). control user account, you need to asign a user password for whom ever need to access the share. (it don't work without a password.)
4). don't forget to reconfigure your zone alarm and Norton, on the ip address part.
5). restart the machine. click on the network place and see if you see the machines. double click on the machine. put in the password. you should be able to gain access to sharing the machine.
Sep 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
I brought a second hand laptop n i want 2 buy more memory so far i have 2gb of memory
THE MEMORY MODULES OF LAPTOPS ARE PLACED BELOW THE LAPTOP IN A COMPARTMENT .. OPEN IT UP AND YOU CAN REPLACE OR ADD NEW MEMORY MODULES AS PER YOUR REQUIREMENT AND SYSTEM CONFIGURATION ... YOU CAN'T INSERT MORE THAN TWO MEMORY MODULES
Sep 15, 2008 | Toshiba Computers & Internet
Memory modules
i don't know this model (amilo pro v2040 ), but usualy the memory modules are one under the other (so u should remove the first memory module to be able to insert the one underneth it) or one facing the other (and there should be no problem in inserting the modules...) If u don't succed, you should be able to find the tehnical book of the laptop on it;s producer site ....
Jan 16, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Ref fujitsu siemens amilo pro v2040 problen
You will then need to repair windows, ensure your cd drive is set as first boot device in bios and insert windows cd and press 'R' for repair instead of install when all the setup files have loaded.
Jan 15, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
491 people viewed this question
David Payne
David Payne
