Question about Polaroid Cameras
My polaroid id 1660 camcorder will not charg
Tried to charge red light comes on but will not charg
    Top Expert:
  • Polaroid Master
  • 63,555 Answers
Then the internal battery needs replaced
Posted on Feb 14, 2015
SOURCE:
jackboy
  • 2985 Answers
SOURCE: when i try to charge my battery the red light keeps flashing
Could be battery or charger. 1. Buy new battery. Still in trouble? 2. Get new charger Its good to have two batteries
Posted on Jun 11, 2007
SOURCE: kodak md853
I've had my camera for a long time so I don't think I'll get the option of taking it back and exchanging it but I keep having the same charging problem. I just tried the flash button trick... the green light is on, steady, and holding. I'm not going to touch it any more and I hope that if I leave it this way for a bit it'll charge up.
My advice is to NOT LET THE BATTERY RUN DOWN past half charge, otherwise it won't have enough power to stay on long enough to register the fact that its plugged in to the computer.
Posted on Nov 21, 2008
mcomijohns
  • 477 Answers
SOURCE: does not charge,red flashing light on charger
Take a nine volt battery and put + to + and - to - for ten seconds and try to charge again if it does not work then you need a new battery.
Posted on May 25, 2009
SOURCE: my camera casio exz75 doesnt want to hold a charge
I had the same problem some time ago. I called Casio Live Support number and they sent me a new battery free of charge that works.
Posted on Aug 03, 2009
  • 7 Answers
SOURCE: Battery will not charge
I found this while searching to find an answer to solve my problem. It worked! Some say that it took them about 20 times... it took me about 7. Be patient and just keep trying! Hope this helps!
My NP 20 gave me the flashing red light of death and I got Casio to replace it. Then I had the same problem with my second NP 20 so I dug around for a way to fix it and I found the following advice on a site called FixYa. It worked instantly and I didn't risk ruining my battery.
ylu1 writes:
I had the same problem as this.
what i did was...
i kept putting the battery on the charger then took it off as soon as the red light came on.
i did this about 6 times.
doing this puts a bit of charge in the battery each time before the charger starts to flash.
after the battery as got enough charge in it it can start to charge.
hope this helps.
Posted on Aug 05, 2009
I bought a Polaroid power pack, a pink one. I have tried to charge my cell phone Without success.
Red means it needs charging..... the light will turn green or go off when fully charged.
Aug 22, 2017 | Polaroid Cameras
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
Dec 30, 2014 | Audio Players & Recorders
Battery charger red charging light blinks once then goes out
Do the batteries charge? Are they charged? The green indicator normally is the status signal that the battery is charged and the red indicates that the battery needs charging or is charging. If you plug in a charged battery, some chargers will flash red momentarily then go out. This is an indication that the charger checked the battery (red light) and if the charge is good, the red light will go out. I hope this helps you.
Oct 24, 2017 | Hilti Drills
I can't get my Polaroid Bluetooth wireless speaker to work!
hold the button down and it will change to blue, then you need to make sure your phone is connected to the speakers bluetooth. then when you play music off you phone it will come out the speaker. the red light is for aux mode - where you plug your phone or ipod in.
Jan 27, 2013 | Polaroid Radio Communications
Addapter connected but not charging for sharp VL-Z500
If not charging,3 reasons may be-
1.Charger is defective.Check adapter
2.Batt is defective.Try with another one
3.Camera is electrically dedective.Can't complete charging.
Oct 20, 2012 | Sharp VL-Z500H Mini DV Digital Camcorder
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
I just bought my 11 year old an ultra hd 2 hr flip video, we cannot even get it to power on, any suggestions?
You need to first Charge your camcorder battery pack.(mine had to charge over night) the first time.  Plug the little arm that extends from the camera into a USB 2 port on your computer and make sure your computer stays ON during the charging, otherwise the camcorder will not charge.
A red light will come on during charge and goes off when charged. If it does not come while plugged in try a different USB port.  Screen should light up temporarily and Red light showing charging on front of camcorder.
IF YOU HAVE ALREADY DONE THE ABOVE, and are having the problem, pull the battery pack out and reseat it back in there again.  maybe connection not good.  OH, and I think mine had plastic covering the metal connections you may want to check that too -remove if so----- BUT the entire white plastic around the batteries STAYS IN PLACE do not remove that.
If that still doesn't work I would try regular AA batteries in it if in fact you have The FLIP ULTRA HD it will take regular batteries too.    IF they work - then maybe you got a defective Rechargeable Battery pack and should contact Flip Video at   http://www.theflip.com/en-us/
Feb 13, 2011 | Pure Digital Flip Video Ultra Camcorder
My Flip Ultra HD has a red light that blinks when I try to charge it. It won't charge, what can I do to charge it?
Make sure you use a good USB 2 port and make sure your computer stays turned ON during the charging or it will not charge. The red light should stay on on the front of the camcorder while charging and will go off when charging is complete.
Try a different USB port maybe also. or if using a USB extension make sure it is a powered extension, and if not, connect the camcorder directly into a USB instead of using an extension.
My extension has a light to show that it is a powered extension.
Jan 31, 2011 | Flip Video Flip UltraHD 8GB High...
Manual for polaroid DVG-720: Easy-Grip Digital Camcorder
Hi just got a Polaroid DVG-720 HD Camcorder and have had it charging for almost 2 days. The red light is still blinking, how long does it need to charge for?
Do I need to have the SD card in while it is charging?
Thanks for your help in advance
Fiona Bannan
Dec 01, 2010 | Cameras
Cameras Logo
130 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
