SOURCE: Compaq Evo N610c No internal sound
No, you need not to install soud/audio driver if its work with external speakers. Its seems that the internal speaker of your laptop has got damaged. So you shuld call your vendor for service. If you are in warranty it will be free for you.
Thanks
Iqbal
SOURCE: internal speakers not working
try reinstalling the audio drivers first
as it seems to be an issue with either drivers or with the sound card
provide more info like
when was it working fine
wots the operating system you are running
SOURCE: External speakers won't work when plugged in to computer
Make sure the balance control in your VOLUME CONTROL icon in windows tray (by the clock) is centered....
There are sliders for each output/input and a balance control for each of these. uncentred they can switch off one channel.
SOURCE: No sound from built-in speakers
This is because of the Operating System XP as there are no drivers for the inbuilt speakers.Install Operating System Vista and im sure it will work after that.
Regards
SOURCE: external speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
