Turned off; let sit. Ran cleaning cycle with approved cleaner. Turned back on, but would not start making ice and/or cooling in "on" position. Turned off again and let sit. Still will not make ice, but will pull water and work properly for cleaning.
After the cleaning cycle, if you drained the tank to get rid of the cleaning/descaling solution, you will have to refill the machine for the initial start. The normal freeze/ harvest cycle will normally fill the unit after the initial start. I have seen several ice makers with this same initial problem.
If this is not the case and your reservoir is full of water, then check water supply to make sure water will flow all the way into the reservoir. Sometimes the makeup water solenoid fails and need replaced. So if cleaning cycle works and fills, solenoid operated water valve is not the problem. If would mean some electric component is not working. The on/off/clean switch not sending on signal. The board, which is located under the top panel of the cabinet, may have a bad contact on the board. Another possibility is the water level sensor may not be in contact with the water. Most units will not start if the water sensor is not in contact with the water level. It normally looks like a metal probe and has a wire connecting to it to the control board. Any parts can be found by taking your model number to Searspartsdirect.com and can be ordered using a credit card and be delivered to your home.
Hope this helps
SOURCE: u-line CLR 60 B ice maker
U-Line's tech line is 1-800-2547. The compressor, condenser fan and circulation pump operating at the same time?
SOURCE: Water leaks into storage bin
open the machine control panel side and cube adjustable thermostat available in side,adjusted in the thermostat screw
SOURCE: U-Line Model ULN-CLR60B-00
call 1-800-779-2547, U-Line's tech support.
Has to be a bad a switch, wiring issue or maybe a control board. pull the service cover and see if the red light is lit on the board (or flashing). Light on (no flashing) indicates the board is powered up and no errors are occurring.
http://www.u-lineservice.com
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
This happens when the teflon on the mold is peeling.(flaking) It pushes water over the side. Otherwise check the clip in the back that holds the fill tube in the water cup. If the clip is missing then the fill tube could be splashing water over the mold
SOURCE: I have U-line ice maker.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
U-Line Model CLR-2060. Noticed that there is a red light illuminated on the circuit board that remains on at all times. Any advice would be greatly appreciated.
