SOURCE: Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
SOURCE: Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
SOURCE: I have the frigidare affinity
You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
SOURCE: MY GE front load washer stops at 45 min 35 min
I had the same problem. Mine ended up being a cut in the pressure switch hose. Here's what I would do to troubleshoot:
1) Clean the filter down bottom one more time. Run a basket-clean cycle and make sure that the drain pump is working. If so, then move to step 2.
2) Do a diagnostic test. Here's some graphical instructions on how to do it:
Grab the codes off the t02 error codes test. There is a reference manual for the codes in a plastic envelope behind the bottom access panel on the front of the washer (panel below the door) -- remove the 3 screws then pull out from bottom. Lookup the codes and see what they mean.
Mine was E22 -- which indicates problem with pressure switch.
3) Do the t06 basket test. If it fails, then open up the top of the washer to check the pressure switch and hose:
Twist the pressure switch 90 degrees clockwise toward the spring to release it. Undo the hose clamps and blow down the hose. Blow into the pressure switch to make sure a contact isn't stuck. I took the bottom panel off the washer and disconnected the other end of the pressure tube from the bottom of the tub. Once disassembled, I blocked the end with my finger to see if the hose was punctured -- sure enough it was. I taped it and reassembled. If after repairing and blowing out, if you still have problems, replace the pressure switch ($60 on Amazon).
