Question about Epson Aculaser C1100 Printer
Loading Cartridge Brand new bought for daughters 21st. Follow all instructions and align to arrows etc. Does not fit firmly and when i try and turn to the lock position toner falls out of the opening and the door will not shut properly. Must be missing something tried for 2 hours with different colours same problem.
  • Epson Master
  • 691 Answers
Have you removed the protective parts? Ensure carousel is in correct position for loading carts. Ensure tram lines down the sides line up perfectly. Don't be afraid to push the cart home firmly.
Posted on Dec 07, 2007
New black cartridge horz lines cleaned head &cartridge roller ; bought new cartridge still lines
Try to clean the print cartridge nozzles:
  1. On the printer control panel, press Menu.
  2. Press the down arrow button until you highlight Clean Cartridge. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  3. Print the document again to verify that print quality has improved.
  4. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
You can also try to align the cartridges:
  1. On the printer operator panel, press Menu.
  2. Press the down arrow button until you highlight Align Cartridge. Press Select.
Jul 28, 2011 | Lexmark P4350 All-In-One InkJet Printer
Have 5400- needs new black ink. How do I get to the instructions on this
You can purchase cartridges online from www.lexmark.com. Lexmark cartridges are also available in some large office supply stores.
To replace a cartridge on your printer, please follow the steps below:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove your used cartridge.
4. Firmly insert your new cartridge.
5. Close the printer cover. Your printer will then ask you to align the cartridges.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Jul 27, 2011 | Lexmark X6570 InkJet Printer
Printer cartridge allignment fails repeatedly
'Printer alignment failed' Error Message Displays on the Product
Try aligning the printer again and put the alignment page on the top of the scanner bed printer will align itself make sure the printouts are facing down
A "Printer alignment failed " error message displays on the product
Follow these steps in the order presented until you resolve the issue. When one of the steps resolves the issue, there is no need to continue troubleshooting.
Step one: Load the correct type of paper
Colored, photo, or used paper can cause the alignment to fail.
1.
Remove all the paper from the tray.
2.
Load unused, plain white, letter, or A4-sized paper with a brightness level of at least 85 into the tray.
NOTE: Look for the brightness level on the paper packaging.
Step two: Align the All-in-One
1.
Press the Setup button ( ).
2.
Press the Down Arrow ( ) to select Tools , and then press OK .
3.
Press the Down Arrow to select Align Print Cartridges and then press OK . The product calibrates, aligns the printhead, and then prints an alignment page.
4.
Click OK to continue.
5.
Recycle or discard the alignment page.
If these steps resolved the issue , there is no need to continue troubleshooting.
If the issue persists , see the next step.
Step three: Check the ink levels
Empty or nearly empty cartridges might cause alignment failures. Follow these steps in the order presented to check the ink levels in the cartridges.
1.
Open HP Solution Center.
Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
Windows Vista: Click the Windows icon ( ), click All Programs , click HP , and then click HP Solution Center .
HP Solution Center opens in a new window.
2.
Click Settings ( ).
3.
In the Print Settings area, click Printer Toolbox . The printer Toolbox opens.
4.
Click the Estimated Ink Level tab. The estimated ink levels display in a new window.
Figure 1: Estimated Ink Level window
Illustration of Estimated Ink Level graphic
If either of the cartridges is empty or low on ink, continue to the next step.
If the ink levels in the cartridges are sufficient, skip to Step five: Clean the cartridges .
Step four: Replace the cartridges
Follow these steps to replace any cartridges that are empty or low on ink.
1.
Press the Power button ( ) to turn on the product.
CAUTION: If the product is off when you open the cartridge door to access the cartridges, the product does not release the cartridges for changing. You might damage the product if the cartridges are not in the dock when you try to remove them.
2.
Open the cartridge door.
Figure 2: Open the cartridge door
Illustration of opening the cartridge door
3.
Wait until the print carriage is idle and silent, and then lightly press down on a cartridge to release it.
NOTE: To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
Figure 3: Press down on the cartridge to release it
Illustration of pressing down on cartridge to release it.
4.
Pull the print cartridge toward you out of its slot.
NOTE: The HP Inkjet Supplies Recycling Program is available in many countries/regions, and lets you recycle used cartridges free of charge. For more information, go to the HP Eco Solutions Web page .
5.
Remove the new cartridge from its packaging.
Figure 4: Remove the cartridge from packaging
Illustration of removing new cartridge from
6.
Use the pull tab to gently remove the protective plastic tape from the cartridge.
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
Figure 5: Remove the protective tape
Illustration of removing the protective plastic tape from the cartridge
7.
Slide the new cartridge forward into the empty slot, and then gently push on the upper part of the print cartridge forward until it clicks into the socket.
Figure 6: Install the new cartridge
Illustration of sliding new cartridge into the slot
8.
Close the cartridge door.
Figure 7: Close the cartridge door
Illustration of closing the cartridge door
9.
Try the alignment again.
Method one: Clean the cartridges from HP Solution Center
1.
2.
Click Settings ( ).
3.
Click Print Settings , and then click Printer Toolbox . The printer Toolbox opens.
4.
Click the Devices Services tab, and then click Clean the Print Cartridges .
5.
Follow the on-screen instructions to choose the appropriate cleaning level.
6.
Recycle or discard the page that prints.
Method two: Clean the cartridges from the Start menu
1.
Click Start , and then click Printers and Faxes .
2.
Right-click your printer icon, and then choose Properties .
3.
Click Printing Preferences , and then click the Services tab.
4.
Click Service This Device . The Printer Toolbox opens.
5.
Click the Device Services tab, and then click the Clean the Print Cartridges tab.
6.
7.
Replace empty or almost empty cartridges.
Step six: Reset and relocate the product
A power reset drains power from the product and returns the product to the same settings after restarting. Plugging the product directly into a wall outlet can eliminate any potential power deficiencies that could cause an alignment failure.
1.
Make sure that you have the product turned on. If necessary, press the Power button ( ) to turn on the product.
2.
With the product turned on, disconnect the power cord from the back of the product.
3.
Unplug the power cord from any power strips or surge suppressors, and then plug it directly into a wall outlet, preferably in another room.
4.
Reconnect the power cord to the back of the product.
5.
6.
Load plain white paper into the tray.
7.
call hp to take advantage of your printers warranty or they can provide you alternative options specially their loyalty program for Out of Warranty printers
hope i help you a bit
Mar 27, 2011 | HP PhotoSmart C4180 All-in-One Color...
Printer reads no cartridge when one is in
Hello
Remove the ink cartridge (or cartridges) from the printer.
Turn the cartridges over so you can see the copper foil portion of the cartridge casing. You'll see many neatly punched holes in this copper tape. Look closely: if any of the holes seem to be torn, with jagged edges, or if there are tears anywhere else on the copper foil, the cartridge has been physically damaged. Replace it. If the foil appears to be all right, continue.
Moisten the tip of your finger. Gently rub it over the small print head on the bottom of the cartridge. The print head will look like a small plastic or glass window. Rub away any old, dried ink that may have collected on the print head. Old, dried ink has "killed" many a cartridge, particularly if you haven't used the printer in a while. Use your finger tip rather than a towel or a cotton swab: Your fingertip won't leave stray fibers on the print head which could cause further problems.
Seat the cartridges back into the printer. Firmly snap shut the cartridge carrier. Let the printer take the cartridge head back to the proper starting position on the track. Close your printer service bay.
Turn off your printer. Unplug it from the power source for 10 seconds. Plug it back in and turn on the printer.
Follow your onscreeen software instructions on aligning the cartridge heads. The alignment prompt comes up each time the printer detects the cartridge has been replaced or moved. Be sure to note whether this is a new or an old cartridge when you answer the dialog questions.
Use a brand new cartridge, one that is freshly packaged, if the alignment process on the old cartridge fails. This will tell you, definitely, whether the problem is a cartridge problem or a larger printer problem.
Replace the printer if no cartridge--regardless of age-- will successfully align in the printer.
Oct 03, 2010 | Lexmark X5470 All-In-One InkJet Printer
How do i change the ink cartridge
Step 1
housing beneath. If done correctly, the print cartridge carrier should move into the loading position near the center of the unit.
Step 2
Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
Step 3
Pull the spent cartridge from the printer.
Step 4
Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
Step 5
Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
Step 6
Close the cartridge lid over the new cartridge until it clicks into place.
Step 7
Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
Step 8
Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
Aug 15, 2010 | HP OfficeJet J4580 All-In-One Laser...
Don't have a manual, just need to know how to change ink and toner cartridges:)
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
  • Step 2 Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
  • Step 3 Pull the spent cartridge from the printer.
  • Step 4 Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
  • Step 5 Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
  • Step 6 Close the cartridge lid over the new cartridge until it clicks into place.
  • Step 7 Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
  • Step 8 Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Read more: How To Change the Ink Cartridge in a Lexmark X2470 | eHow.com http://www.ehow.com/how_6646584_change-ink-cartridge-lexmark-x2470.html#ixzz0wg8UCkTs
    Aug 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
    How do I change the ink cartridge on my Dell 810 printer
    Ink Cartridge Maintenance Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
    rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
    To align the ink cartridge:
    1. Load plain paper. For more information, see Loading Paper.
    2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
    In Windows 2000, click Start® Settings® Printers.
    1. Right-click the Dell AIO 810 icon.
    2. Click Printing Preferences.
    The Printing Preferences dialog box opens.
    1. Click the Maintenance tab.
    2. Click Align Print Cartridge.
    3. Click Print.
    A blue and black alignment page prints.
    1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
    1. Press the Scan button scanicoa.jpg .
    The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
    Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
    http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
    Hope it helped.
    Nov 22, 2009 | Office Equipment & Supplies
    Mfc 845 will not with black ink. The ink cartridge is new. Will print in color. I ran it thru the cleaning cycle. Only prints the top half of sentences.
    This sounds like an alignment issue. Please refer to this support artilcle and follow the instructions given there to align the cartridge. You may have to reseat the cartridge, by carefully following these instructions. Make sure the lock release lever is firmly engaged. (clicks).
    Otherwise, you have as mentioned cleaned the print head, though you could try cleaning again if the alignment doesn't correct the error. For other support help, please see here.
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Oct 09, 2009 | Brother MFC-845CW InkJet Printer
    Instructions on installing & changing ink cartridges
    Step ten: Install the cartridges
    1. Make sure the product is turned on. The On button is lit when the product is on.
    2. Lift the cartridge door. The carriage moves to the right side of the product. Figure 12: Lift the cartridge door c01331661.jpg
    3. Remove the new cartridge from its packaging and gently remove the plastic tape using the pink pull tab. Figure 13: Remove the tape c01331662.jpg CAUTION: Do not touch copper-colored contacts or retape the cartridges.c01331663.jpg
    4. Slide the tri-color cartridge into the left slot. Push the top part of the cartridge firmly up and into the slot until it snaps into place. Figure 14: Insert the tri-color cartridge c00620861.gif
    5. Slide the black or photo cartridge into the right slot. Push the top part of the cartridge firmly up and into the slot until it snaps into place. Figure 15: Insert the black or photo cartridge c00620862.gif
    6. Close the cartridge door.
    Step eleven: Align the cartridges
    1. Make sure you have loaded plain white letter or A4 paper in the bottom tray. Press OK to print the alignment page.
    2. Remove the alignment page from the output tray. Figure 16: Print the cartridge alignment page c00620112.gif
    3. Place the alignment page face down into the document feeder. Figure 17: Load the printed alignment page c00620113.gif
    4. Press OK to scan the alignment page. After the page has scanned, alignment is complete
    Apr 12, 2009 | HP OfficeJet 4315 All-In-One InkJet...
    I have a hpdeskjet f2180 and need to change the ink cartridges. How do I get to the cartridges to change them !
    Installing print cartridges
    1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely when you try to remove them.
    2. Open the print cartridge door. Figure 1: Opening the print cartridge door c00906461.jpg Make sure the print carriage moves to the center. If it does not move to the center, turn the device off and then turn it back on again.
    3. Remove the tape from both cartridges. Figure 2: Removing the tape from a cartridge c00651128.gif CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 3: Copper-colored contacts c00651129.gif
    4. Hold the cartridges with the HP logo on top.
    5. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Figure 4: Carriage slots c00853116.jpg Figure 5: Inserting the tri-color cartridge in the left slot c00853117.jpg
    6. Make sure you push the cartridges in firmly until they snap into place. Figure 6: Pushing the cartridge in firmly c00853118.jpg Figure 7: Tri-color cartridge and black cartridge correctly installed c00853119.jpg
    7. Close the print cartridge door. Figure 8: Closing the print cartridge door c00906462.jpg
    Aligning print cartridges The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print cartridges ensures high-quality output. NOTE: If you remove and reinstall the same print cartridge, the HP All-in-One will not prompt you to align the print cartridges. The HP All-in-One remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. To align newly installed print cartridges
    1. Make sure you have letter or A4 unused plain white paper loaded in the input tray. The HP All-in-One prints a print cartridge alignment sheet. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
    2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left. Figure 9: Loading the alignment sheet c00906464.jpg
    3. Press the Scan (c00906465.jpg ) button. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
    Jul 29, 2008 | HP Office Equipment & Supplies
    Epson Aculaser C1100 Printer Logo
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
