check and make sure the timer is not stuck in defrost mode. if you can turn the timer by hand past the current point it should advance past the defrost cycle and begin cooling. The timer is usally found near the bottom of the refrig located in the front side.
We realized the other day that everything in the freezer wasn't frozen, and the rifrigerator side...
(More)
We realized the other day that everything in the freezer wasn't frozen, and the rifrigerator side wasn't as cool. We turned up the dial to a cooler setting. It still is not as cold as it should be. We ended up having to empty out our freezer side, and are concerned about the temperature in the refrigerator side. The model # is FRS22ZRF. Help!!
six months ago, the ice cube machine dident work, now the temperature of the freezer all of a...
(More)
six months ago, the ice cube machine dident work, now the temperature of the freezer all of a sudden, drop and, eveeything in the freezer is icy.
microwave runs for a few second than turns off
I had the fan on for a while, and then when I tried...
(More)
I had the fan on for a while, and then when I tried to use the cooking at the same time, the fuse (dedicated 20 Amp line) blew off.
Ever since, I switch the fuse on, I turn the microwave on, and on the first second - it turns off, blowing the fuse off.
Please, help!
There is water dripping on the inside of refrigerator (underneath icemaker). It is a Kenmore Top...
(More)
There is water dripping on the inside of refrigerator (underneath icemaker). It is a Kenmore Top Mount Model 106.72104100.
