It start wenn I turn on machine she take wather and before it starts to wash then appears Error E02. So I wanna no what can be the problem is it heater or something else?
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Depends on the make and model but an Error code E02 on most washing machines is slow water flow probably caused by a blocked filter! Remove panel on front bottom left or right side and clean filter! Should then clear error itself!
i have found the problem i thought it s was the sonda but the wather was liking in ithe conector in the motor that give him poover make the sortbrake pover then the elecricity of the machine breks out so it dost give the power to the sonda down
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
I've encountered this a few times. I still haven't been able to find out what the E02 stands for, but if you unplug the machine, wait 30 seconds, then plug it back in, it seems to work fine.
Than means your heater relay is stuck and you either have to service it or........... repair it your self HERE you can buy the parts you need or you can locate an other dealer online with google.
Goodlukc
