Question about HP ScanJet 2400 Flatbed Scanner
Can not print graphics in document
When an attempt is made to scan an invoice the image does not pick up some of the column and row lines. Also some of the text appear on the wrong side of the lines
The scanner does not give you the ability to change the resolution.
rfernandez@eagle-it-solutions.com
  • 55 Answers
Have u checked,the driver software reinstalling,u also try to preview n scan image by going to my computer ,right clk on the icon hp 2400 scanner ,clk get pictures,fist check preivew,then scan.check for the results ?,if not ok ,pls revert for further solution
thnx
Posted on Jan 25, 2008
Why Can't I print documents?
What application are you printing from?
Are you trying to print a PDF with a lot of scanned images or embedded content? Large PDFs can bog down printing.
Try to find a simple text-only PDF (no graphics or scanned stuff) with only a few pages and print it.
Some third party PDF generators do not make clean PDFs. They are malformed and can cause issues when printing.
Jun 07, 2016 | Epson Stylus Office Equipment & Supplies
BLACK MARK ON THE COPIES OR SCANNED IMAGE
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
Jan 17, 2014 | Sharp Mx-C402sc mx-C402sc
Misaligned printing of row and columns
Hi Myles,
Please perform print head alignment procedure first. You can access this function from maintenance menu on the printer driver.
Be sure also to print the document in high quality mode when you meet such the problem. If the problem still persist you may need to clean film timing slit of the printer.
The following may be useful for your problem. Good luck.
Print Head Alignment Correct The Misalignment of Colors and Lines
Jan 14, 2014 | Canon PIXMA MP780 All-In-One InkJet...
I can not scan from my HP Photosmart C7180 All in one. Mac OSX 10.6.8 I can copy, print but not scan.
Launch the OSX system preferences, click on the Print & Scan Icon located in the Hardware row, select your printer in the left hand column, click the Scan button above the right hand box, click on the Open Scanner button, a new window will open, click on the scan button in the upper right hand corner of that new window, set your document on the flat glass panel of your multi function printer/scanner, and click the scan button located in the lower right hand corner of the window, once scanning is complete, your document image should appear in a new window and save the image from there.
Dec 22, 2013 | HP Photosmart C7180 All-in-one Printer Fax...
Vertical Black Line
Probably there is nothing wrong with that scanner, just open and clean document feder with alcohol or glass cleaner.
Mar 29, 2013 | Canon PIXMA MX870 Wireless Office...
My color black does not print at times
Hi mserio007,
Please perform a deep cleaning.
1. Press the button on the printers operation panel.
2. Press the left [] arrow buttons to select [MAINTENANCE].
3. Press the button.
4. Press [] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
5. Press .
6. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
If this does not work, then It seem the contacts on the print head are damaged and you have to replace the print head to resolve the issue. But before that you can follow the steps below to remove the print head and then cleaning the copper contacts on them with a cotton swab dampened in distilled water until they are clean after drying them check the issue if the problem persist then replace the print head to resolve the issue.
1. Make sure the power is turned on.
2. Press [Open] and lift up the scanning unit. The print head holder automatically moves to the center of the machine.
CAUTION:
Do not try to manually move or stop the print head holder.
Do not touch any metal parts.
Press on the tab to release the ink tank, then remove it from its slot. Repeat this process until all ink tanks have been removed from print head.
3. Lift up the lock lever and take out the print head.
4. Reinsert the print head.
5. Insert the ink tank into the empty slot on the print head. Press down gently on the top of the tank until an audible click is heard. Make sure the ink tank is inserted into the correct color slot.
6. Close the scanning unit until it locks into place.
7. When the LCD displays [ALIGN PRINT HEAD], press on the operator panel. The machine will print a horizontal line pattern, and the LCD will display [CHANGE H VALUE] on the top row and [A 0] at the bottom row.
(A): Column A
(0): Value for Column A
8. In column A on the printout, note which box has the most solid image. Note the value next to this box and use [Left cursor] or [Right cursor] on the operator panel to enter it then press .
9. Repeat step 9 for columns B to K.
10. When values for all columns have been entered and the LCD displays [PRINT VERT. PATTERN?] on the top row and [YES=(*) NO=(#)], press [#] to return to standby mode.
Hope it helps.
Thank you for using FixYa.
Aug 24, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
My printer will not print. I recently changed ink cartridges and I'm getting a message suggesting that I realign something. How do I do that?
Most all-in-ones require you to scan an alignment sheet after changing the ink. Make sure the printer is on. Press Menu then use the up and down arrows to navigate to Maintenance. Click OK. Navigate to Auto Head Align and press OK. Select Yes and press OK. Load a sheet of Letter or A4 sized plain white paper in the rear tray, follow the on-screen directions. Open the output tray gently and the output tray extension. Press OK. When the page prints out, do not touch the printed sections. You should see a set of broken lines on the page, among other printing. The first section of columns will have 2 black, 1 blue and 3 black. The next row has 4 columns (blue and pink (to my eye)); the final row is 3 blue and 3 pink. If this prints okay, then select Yes and press OK. Next place the printed page face down on the glass of the scanner unit so that the black triangle at the top left of the page is in the left back corner of the glass. (The triangle is an alignment mark and lines up with the alignment mark on the edge of the scanner unit.) Close the document cover and press OK. The sheet will be scanned and the print heads will be adjusted. Do not open the document cover or move the sheet until the unit has completed the adjustment. Afterwards you can discard the sheet.
If the unit fails to adjust the print head, it will indicate this in the LCD screen. In that case, try manually adjusting the print head from the Canon Toolbox on your computer. If you can't get the printhead to align properly manually, the unit may need service.
For pictures, see the manual or support for the all-in-one here: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp490#ServiceAndSupport . If you use the Support option, search for align print head.
I hope this helps.
Mar 16, 2011 | Canon MP490 InkJet Printer
Why doesn't my printer let me print assignments like resumes etc???
You may have used a template to make a resume. I am assuming you use Microsoft word to do your assignment. If that is the case, you start with a blank sheet of paper. For example,If you would like to have rows and columns, click on table then insert rows or columns and use tab button to move from one column to other. Basically, in the absence of a template you need to do your own design of the page.
Even after that you need to check how the printer is going to print it. To do that, Click on file. Scroll down to print preview. Click on that. When the page opens it will show how exactly the printer is going to print. (You may notice some lines you had on the original document is missing in the new view) If what you see is not what you need, then make necessary changes in the original document. For example borders on table properties. Once done, come back to preview.
Jan 29, 2010 | Canon MultiPASS MP390 All-In-One InkJet...
When I print some documents such as a book I am working on that has pictures of tombstones when it prints them (there are 6 on a page) it is just printing a partial picture like the top and does 2 or 3 of...
Go to "printer&faxes" on your start up menu.Click on your printer and in the left column you'll see "get pictures".Click on that and pick your preference.Click next and it will scan your document,then put it where you want for viewing.Works for me!
Dec 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
Scans @ 75-80% of original size..how do I get it to scan @ 100%
the only thing I can think is the scan or print settings on the printer itself. there should be a way to adjust the size from either the printer or the preferences on you computer in the print screen.
Feb 27, 2009 | HP Officejet 6310 All-In-One InkJet...
HP ScanJet 2400 Flatbed Scanner Logo
62 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
