Question about Dryers
Dryer inside drum not rotating.dryer heats up but no tumbling of clothes.
  • 5 more comments
  • tman2300 Nov 14, 2007
    kenmore dryer 70 series
  • dan griffin
    dan griffin Nov 17, 2007
    I have the same problem with a Whirlpool dryer, model # LER4634JQ1. The element heats up but no tumble. The belt is fine and the drum can be spun by hand with no problem. I figure it's the motor but cannot figure out how to remove the motor.
  • andrew harris Mar 05, 2008
    drum not rotating
  • luvnikkibabe Dec 23, 2008
    I have the same problem..Kenmore 70series model # is 110.76732500. Please help! It "appears" as though the belt is loose? Not really sure what the issue is.
  • Anonymous May 07, 2009
    dryer turns but does not
    heat
  • Anonymous Mar 23, 2014
    drum not rotating but heat is
  • Anonymous Mar 29, 2014
    dryer used to be quiet now the drum rotates and dries clothes but is incredibly loud like metal against metal as it spins and tumbles clothes. did a belt break?
I have a dlg 2532w that has a bad vibration, when you place your hand on the drum while it is spinning the vibration seems to go away somewhat. It is 4 yrs old and it gets used alot, do you think this is a belt problem or possibly a motor issue?
Posted on Jan 26, 2008
  • 5,911 Answers
There's only a couple of things that will cause the problem you just described. A broken dryer belt, or a defective drive motor. However, most drive motors are equipped with a centrifugal switch that closes when the motor turns. Without this switch closed, the heating circuits would not energize. So...I would recommend you check to see if your dryer belt has broken. If you can post back with comments on BRAND name and MODEL number (located along the inside of the door opening somewhere, or on the back of the console) I can give you advice on how to repair this yourself. Let me know. I hope this helps you.
Posted on Nov 12, 2007
  • Jeff Rockwell
    Jeff Rockwell Nov 14, 2007
    Okay Kenmore is the Brand name and the 70 is the series, but I need still need the model number. It can be found along the inside of the door opening somewhere. I need that number in order to locate the correct part for you.
No heat from tumble dryer
Hi.
If dryer is electric check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, element and fan.
If dryer is gas check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, igniter, coils, burner, flame sensor and fan.
Dec 14, 2011 | Washing Machines
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
How does tumble dryer work?
The heated air inside the dryer is not expelled but reused. The drum is contained inside a closed area. The heat is contained inside the dryer. No ducting to outside is needed. The moisture is removed from the heated air through a condenser before re-entering the drum. Sorta like a giant self-contained dehumidifier. As the water is removed from the clothes, it puddles up into a drain pan which periodically needs dumping. Fancier models pump out the water to standing drainpipes. This design saves energy.
Apr 11, 2010 | AEG T58840 Dryer Electric
I have a kenmore 80 series electric dryer. It gets
If your dryer doesn't tumble, check these: Belt Motor Door switch Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time. Click here for a belt installation diagram Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks for choosing fixya...Regards, Joe
Nov 13, 2009 | Cars & Trucks
Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Ultimate care ii Dryer wont tumble
Belt,
Motor,
Door switch.
Remove the belt,
Check for obstructions in the blower fan housing,
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Tumble dryer drum wont rotate is it my belt .if so how do i replace it
yes it is the belt,what make and model number(inside dryer door or on it,let me know and we can go from there-mike
Oct 02, 2008 | Dryers
Kenmore electric dryer
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Click here for a belt installation diagram.
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
Aug 27, 2008 | Dryers
Dryer does not tumble, but heats up
  • Remove the belt.
if this helps please vote me a fix ya
Jul 15, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Dryers Logo
319 people viewed this question
Top Dryers Experts
