Question about Irons
Tefal express Hello There, I have just inherited the above iron from a relative who has just died. There is no instructions with it. Although I have it working, I don't know why it sometimes makes a rumbling noise and what the on switch is came on without pressing that.....and if its ok to use asda cheap bottled water in it as I live in a hard water area. I also need to find out about descaling.......sorry....lots of questions, thankyou, Margaret Cox.
Re: tefal express
How so I descale my standing rowenta steamer that is turning on, but not producing steam?
Posted on Aug 21, 2008
0 characters
3 Points
Tefal Pro Express GV 8120 Iron. New Iron - will not heat up and turn itself on. Green light just keeps flashing.
If it is a new iron, take it back to the dealer. Any attempt to repair or adjust on it will void the guarantee.
Jan 26, 2011 | Tefal Pro Express GV 8120 Iron
Tefal 2932 pro express iron not steaming
Use different water in the iron...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
May 14, 2010 | Tefal Ultraglide 1549 Iron
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Feb 17, 2009 | Tefal Irons
Tefal Pro Express - Constant Steam (Model 2932)
Great answer from Jacquief above. To which I add try giving the base of the iron and its button, a very light tapping with a tack hammer (much smaller and lighter than a standard hammer) wrapped in a tea-towel. This can often break up the lime scale seal which has formed somewhere inside and is not responding to Jacquief's method. In future never use scale laden tap water in your iron, use $2 litre bottles of distilled water from any supermarket.
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
Tefal express
The rumbling noise is the steam generator working - make sure the water reservoir is full and press the on button. Inside the machine will be doing its stuff and generating steam - this is the noise that you are hearing and when you press the release switch (normally under the handle of the iron) then the steam will be expelled. The noiose comes on and off as it is making more steam - this is normal. I use ordinary tap water but don't have hard water so have no problems - also make sure you empty out the base occassionally - should be a large pressure screw behind the cable holder - make sure iron is off and cold before doing this and then shake it out and residue bits will come out - then flush out with water. These are brilliant to use and you will wonder how you managed before having this - Happy ironing.
Aug 23, 2008 | Irons
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Irons Logo
863 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
