I have a weather king furnace that runs alot more than it should n blows cooland sometimes cold air . i checked the furnace and there isnt any blinking lights .. but there is a hole in the bottom of t
Ive taken the door off n checked, no blinking lights there is a flame when the furnace comes on
Hi Shane Dann, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hi Shane Dann, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
When the furnace first comes on there is a induced draft motor that should come on first but that forces air up the exhaust or flue,not into supply air on ductwork. It is not unusual for cold air to be blown out when burner first turns blower motor on. This should last for a short period of time, no more than a min. or two. You can watch furnace cycle by removing top front cover, I should back up here and ask is this a gas or electric unit. If it is gas you should be able to watch burner flames for a short time before blower comes on. I really need more information so I can try to ascertain what is going on. Wish I could be more help. Thank you.
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Your in house core could have frozen over. check the core inside the indoor blower unit. it may have frozen over. this will interrupt the cold air function.
Check your flu pipe and make sure there is no obstruction in the entire pipe. Sometimes the exhaust fan for the flu will not come on because the safety will not allow it to and it will also cause the fan to run, but not the burners to engage ignition.
Hope that helps.
God Bless.
Erik
