Cars & Trucks Logo
k
karen gill Posted on Jan 25, 2015
My cd player of my suzuki swift will not play my cds it keeps displaying error 1 what does this mean?
Radio works but cds just keep wirring and displaying error 1 message
Michael Stevens
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Jan 26, 2015
Michael Stevens
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
2731
Points
CD PLAYER PART OF RADIO NEEDS TO BE FIXED BRING TO CAR INSTALLATION PLACE TO SEE IF THEY CAN FIX CD PLAYER IF NOT JUST BUY A NEED RADIO THERE FOR ABOUT 200.00
I have a 2006 suzuki aerio SX.my radio keeps inserting and rejecting my cds and gives me and error code E 02 what does it mean.
  • bad CD
  • wrong CD
  • or CD drive bad.
not told you,.what is on that CD
off the shelf music CD, called CD_DA disks, real music disks
or copies of CD to CD-R recorded media
or a mix CD from friends, in MP3 format or 20 other formats no car can play
What does error code E-01 mean? CDs won't play and cannot eject trunk unit.
thats what i do with mine ,the phone thing but error E 1 means that a cd is jammed in the unit,happens to me all the time as i only use it for jaguar meetings .Now what you do is to pull out the cartridge and remove all the CDS then re insert it and press the eject button again and it might if your lucky retrive the cd in the player and return it to the cartridge ,.then refit all the others till it happens again
Radio not working
no year car>??????
2002 , 2007, what?
real fresh CDDA music discs, real as in not copied? or ripped?
store bought CD, that fails.?
the the CD drive is bad. get it serviced or upgrade it to USB,
and put your music on stick and end CDs for ever. and ever like us..
or use aux port and MP3 player for $20
2answers
2007 toyota camry cd player reading error 1
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Cd player keeps going out when i try to play/load/reject get 'error' message
Take out #7 and #31 fuses. Start the vehicle, the radio/cd will not come on. Shut the vehicle off and replace the fuses. Start the vehicle again and you shoud hear the cd player cycling through the cds. Be patient and let it go through the process. Then play/eject/load cds. It worked for me.
1helpful
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
9helpful
3answers
CD disk error
ok error code 1, look for this error code on your owners manual, toyota cd players give 3 error codes, this mean error code 1, error code 2, and error code 3, they all have different meaning please check owners manuel to see what does error 1 mean i will try looking for you
CD player won't play CDs
Try getting a cd cleaning tool come with a disk with tiny brushes on it and cleaning solution to clean the eye or if you are using burned cds try and see what format you are buring such as mp3s mp4s some cd player only will play a certain formats such as mp3s.
1helpful
2answers
Toyota Avalon 2000 xls cd player does not work
If you are using "home-made" or "burnt" CDs, this can happen. Sometimes, you can remove the radio from the dash, and unplug it. That may reset the CD player, and the discs will eject.
It works for me about 85% of the time. Hope this helps.
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
