Question about Zanussi WJS1265W Front Load Washer/Dryer
Fault code machine keeps coming up with fault code E90
E90 indicates a communications error between the user interface board (control panel) and the main circuit board. If you take the top off the machine (power off first!), then stand in front of it and look at the front left you'll see the main board and a blue multi-stranded cable coming out of it and going into the control panel. 99 times out 100 this is the culprit, if there's a poor connection at either end then this generates E90. You need to remove the control panel (screws behind soap drawer and plastic clips along the top), disconnect the blue cable, give the connector a bit of a squeeze with your pliers to tighten the connection, do the same to the other end on the main board, refit everything and away you go....hope this helps...yes I used to work for them
Posted on Jan 06, 2008
I think it means that it is not emptying, disconnect the water drain waste pipe and drain the water into a bowl, it might take a few bowls of water so have someone help, i had this problem and also weird things like the door locking before i had started a program, i took the machine out of its slot took the lid off and unclipped the connectors to the main board which is on the right hand side at the front if your standing in front of the machine there is a screw which holds the board in place,i sprayed a little wd 40 on the connectors and put them back on since then touch wood no more probs
Posted on Dec 08, 2007
E90 fault code
E90 is usually a Major Fail Code ? this video is Very Noisy although in formative, hope this helps? E90 Error: http://youtu.be/IhHvw2K7XO0
Feb 22, 2015 | Washing Machines
Machine flashing E90 and not working.
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer.
Jan 16, 2011 | Washing Machines
I have a electrolux front loader ewf 1087 that shows the code e90 on start up...i have cleaned the plug that the blue wires go in to & still flashes e90 con soneone help..thanks
Jan 10, 2011 | Washing Machines
Can anyone help ive got a zanussi FJDR 1466 W. e91
I had the E90 problem about a year or so ago. Havng had a problem with my Zanussi dishwasher a common fault with zanussi white goods is that they don't solder major joints on the control boards very well. (Probably tryng to economise of the amount of solder they use)
Check all the connections on the control board are tight and haven't burnt off the solder. This worked for me and we haven't had this code since.
Nov 02, 2009 | Zanussi ZWF1430W Front Load Washer
Washing machine displaying E90 error
an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Dec 12, 2008 | Maytag Neptune FAV6800AW Top Load Washer
E90 code on a zanusi jet syatem turbo dry 1600
A E90 fault code means the main pcb board is faulty and i'm afraid to say, they are a expensive item and not always easy to replace, some come pre programmed and just swap across and others have to be programmed using the code on the white sticker on the board housing. either way it normally better to get a engineer to replace it because you don't get the programming instructions with the new pcb. I hope this helps
Jul 14, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi jet system 1000
Jul 09, 2008 | Zanussi FJS1225W Front Load Washer
Fault code
Click on 'troubleshooting' above & enter E90 error; you are sure to get solutions.
Dec 04, 2007 | Zanussi FJD1666W Front Load Washer
Zanussi washing machine
E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
E90 Error Code
Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi WJS1265W Front Load Washer/Dryer Logo
310 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
