Televison & Video Logo
Elizabeth Leon Posted on Jan 25, 2015
What channel to play videos on element tv
Name of channel on TV for DVD player. Don't have AUX as an option
1helpful
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
3answers
2answers
Sony RDR-VX535 I tried hooking it up to just a TV, no cable box or anything else. I put the 3-pin cable from the Sony's Output to my TV input (only has yellow and white on TV, no red). However, when I...
Red is Audio Right
White is Audio Left
Yellow is Video
You don't say what TV you have so it's impossible for me to guess what the connection it is that you are using. You will not see a signal on any of the channels you will need to select AV or Mode or Input or something similar on the TV
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Cannot get dvd to play through tv
Check Your Remote For A Tv/Video Button.
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Trying to hookup and play standard DVD player
Yellow is video and red&white audio ,so when you hook up dvd does picture preview of dvd come on?You may have to switch to aux for dvd or different channel try checking each channel .
1helpful
2answers
Am I connecting DVD player wrong?
on some of these older RCA try simply tuning it from the remote down to chanel 01 or 00 this may work. if not you have to go into the setup menu of this set and enable the aux inputs
Can't get TV onto the AUX channel
Do you have the correct scart socket plugged in this is usually a common problem easily sorted..
swampy
1helpful
6answers
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
