Question about Janome Memory Craft 9000 Computerized Sewing Machine
Having a problem with tension not stitching correctly what can I do to fix it
Have tried to stitch garment a few times but it is not stitching properly how do I adjust tension please
    Genius:
  • 1,407 Answers
Tension depends on so many things. Material thickness, right size needle, thread,bobbin etc . If it is none of these things then you need a technician.Best wishes
Posted on Jan 25, 2015
  • Janome Master
  • 688 Answers
Here's how to adjust bobbin tension: 1 Remove bobbin and carrier.
2. Put bobbin in (spinning counterclockwise) - thread inserted under plate. (tension).
3. Place on flat surface and pull thread while holding carrier in place. Adjust small screw until you feel it is slightly difficult to get the thread to move. The old style machines you bob it from your finger until the adjustment allows it to move one inch downward.
4. When you have this done put one drop of sewing machine on the race (small track the bobbin carrier rest).
5. Replace the bobbin carrier and bobbin. The thread must be able to go under the holders of the carrier so you may have to make a slight adjustment.
6. Go ahead and thread the top with the foot up. As you thread the top you may make little pulls. This is to insure there are no snags. With the foot in the up position the tension does not operate. When you put the foot down the thread should be noticeably more difficult to pull.
7. The upper tension should be at about a four setting to start with.
8. Adjust the upper tension this way. If too much thread is coming to the top from the bobbin then you should lower the top tension. The opposite is true.
Posted on Jan 26, 2015
SOURCE:
bargainbox
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
mallow1
  • 35 Answers
SOURCE: Thread tension?
I own this little gem of a machine. It definitely sews a perfect stitch. I'm assuming you own the green 3/4 size machine as denoted by your product number. The half size blue one pictured is incorrect.
Anyway, this machine sews a perfect stitch, due to the oscillating bobbin. Most sewing machines with rotary (drop in) bobbins don't have an easily accessible bobbin tension screw, which means your fabric is usually slightly puckered. Fiddling with only the upper tension helps very little. This frustrates me to no end for sewing long curtains, clothing side seams, etc. Wrong tension causes them to hang with puckers, making them look awful. With the Hello Kitty 3/4 size Janome, there is a screw on the bobbin case which allows you to adjust for every thread diameter perfectly. Always a perfect stitch, if you take the time to adjust this screw.
To adjust the bobbin for a perfect tension, load the bobbin into the bobbin case and thread it through the guide. Holding only the thread between two or three fingers, let the bobbin case dangle below. This will be slightly difficult, because the bobbin will want to fall out of the case. Don't worry, just don't move it around too much and it will stay in long enough for this test. If the metal bobbin case slowly drops lower, unwinding thread as it goes, the thread is too loose. Tighten the screw on the side of the bobbin case a little (about a quarter turn.)
If the bobbin case seems to be dangling firmly, give the thread a gentle tug, lifting up fairly quickly. If it doesn't release a couple of inches of thread, it's too tight, loosen the screw. You know the tension is perfect when a quick, light tug of the thread releases a couple of inches of thread.
Posted on Aug 16, 2008
SewTechWayne
  • 186 Answers
SOURCE: The Reverse stitch button
The feed mechanism needs to be oiled. Take off the bottom cover and look for any place where two parts move against each other. Some binds can be very difficult to remove. Try spraying everything with a light weight oil (I like Tri-Flow) and let them soak over night. Then manually try to move the feed dogs with your hand. Hopefully it will break loose.
Posted on Jan 30, 2009
SOURCE: skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Posted on Mar 15, 2009
rochelle0099
  • 5 Answers
SOURCE: no stitch happening
May sure you are using the correct size of needle and thread suitable for the fabric. make sure the thread in the bobbin and the needle is of the same weight or size. Make sure the needle is changed often - after the completion of an garment. After much use the needles become blunt and cause problems with your stitches.
Also, if the bobbin is jamming that is normally because the machine is threaded incorrectly, or the bobbin case thread is wound unevenly, or the bobbin case is not put in properly.
Try this! Just stop for a while, give yourself a few minutes to relax. When you return pull the User's Manual and slowly go over the instructions, especially the "troubleshooting" section. Also, rethread the machine and the bobbin case by carefully following the steps in your User Manual. I have found that it helps me tremendously when I have problems. Hope it help. Happy Sewing
I have similar problems
Posted on Aug 02, 2009
Testimonial: "Thanks, and after having a few days break, my machine seems to be nearly back to normal, it is working on normal cotton but not on stretchy material."
The bottom stitch is not catching, so when I'm finishing stitching the line of stitches is easily pulled out. I've tried loosening and tightening the bobbin.
Not sure if I'm understanding. Is it stitching but the bobbin thread simply lays on the fabric surface? If this is the case. The top tension is too loose. Bobbin tension is usually altered only as a last resort since it is difficult to correct,. Tension is correct when both threads meet in the middle of the fabric. Tension is a tug-of-war between the two threads. When both threads have equal pull, you have achieved correct tension. So, in your case, if you tighten the top tension, it will pull the bobbin thread up.
However, if your machine is not creating stitches, you should try installing a brand new needle. If that doesn't help, then most likely your machine is out of time (needle & hook are out of sync) and needs service.
Feb 03, 2018 | Sewing Machines
My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
Nov 29, 2015 | Sewing Machines
How do I get my sewing machine to sew with correct tension and straight stitches?
Over time, internal adjustments and servicing is required, at a sewing centers, service dept.
Take it in, have them look and repair, pay the nominal charge!
you will be glad you did!
Apr 16, 2015 | Sewing Machines
Having a problem with stitch tension can you help
is it just the fabric that is gathering or the bobbin thread also ?
Jan 24, 2015 | Janome Memory Craft 9000 Computerized...
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
Jan 06, 2013 | Singer 1507
Can you sew leather or vinyl on Husqvarna 415? If so, what tension, needle and foot should I use?
Ok. Depending on the thickness... garment weight leathers can be sewn with a domestic machine... Most often an even feed foot (the home version of a walking foot) is needed. You will likely need a larger leather needle and somewhat longer stitches than you would normally sew.
As for stitches looking messy on the back that is a top tension problem... you'll need to tighten the tension until that goes away. AFTER you have made sure you have your machine threaded correctly with the presser foot in the up position.
Aug 19, 2012 | Husqvarna Freesia 415
Ult2003d character decorative stitches
I would suggest having the machine checked, there could be something wrong with the computer.
May 10, 2012 | Brother Sewing Machines
I love my machine except when trying to free motion quilt. No matter how loose I set the tension it still pulls the bobbin thread to the top. I also have trouble with the thread breaking and stitches...
Properly balanced tensions are critical. The lower bobbin tension must be tight enough to pull the knots down. To which number is your upper tension set? It should be around three. Skipping stitches is an indicator of hook timing and hook/needle clearance issues.
Sep 01, 2011 | Juki TL-98Q
Topand bottom stitches are not even
Could be a tension issue.
Try this to see if it helps:
Remove top thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Start the top tension set at the midway point and then adjust.
Check that the bobbin is threaded and installed correctly.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Apr 22, 2017 | Singer 7436 - INGENUITY
Janome Memory Craft 9000 Computerized Sewing Machine Logo
100 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
