I don't have the wiring so i cant try anything
Depending on age of unit, service manuals can be downloaded directly from Clarion.
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information proves beneficial.
SOURCE: I need a wiring diagram
to what car is it being fitted?
standard stereo wireing is as follows:
SPEAKERS
+White -White/black Front left
+Grey -Grey/black Front right
+Green -Green/black Rear left
+Purple -Purple/black Rear right
POWER
+12v Con Yellow
+12v Ign Red
+12v Antenna Blue
-12v Return Black
Tele mute brown
Illumination Orange
Hope this helps somewhat.
SOURCE: clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
SOURCE: WIRING DIAGRAM
red is ignition power, or power when you turn the key on. yellow is all time power. yellow keeps power all the time, this keeps your presets and clock settings saved. black is ground. once you have then hooked up you will be able to figure out your speaker wires by trail and error, they my be green/green black, purple/purple black, white/white black, ect, but these are your speakers. Once you get the power on it should be no problem to figure out the speaker wires.
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
SOURCE: clarion db165, need a wiring diagram
i have a clarin db165, and i need a wiring diagram or color sheet.... please! i've looked a;; over the internet with no luck.
