Question about Toshiba Satelite 5205-S505 Notebook
Replacement of Hinges for screen of Toshiba Satellite S2410-603 model
  • ngray Dec 23, 2007
    Both screen hinges are broken and I have to prop up the laptop screen to use. The hinges are located inside the speaker on the base. Where can I purchase hinges and how hard are they to install?
  • Anonymous Aug 12, 2008
    yes i have
I have developed a TOSHIBA BRAKE HINGE revision set. It is applicable for Toshiba hinge partnumbers:
P000392930/40
P000377630/40
P000379650/60
P000392250/60
P000394150/60
P000380770/80
P000347860/50
P000349070/60
P000353180/90
P000368300/10
P000378510
See www.impactcomputers.com for models
You need to disassemble your notebook yourself.
See www.irisvista.com
For detailed information mail me: tjanssen@chello.nl
Posted on Apr 07, 2008
  • 58 Answers
You can check on www.ebay.com by typing Satellite S2410-603 and check there for a possible part.
Posted on Jan 15, 2008
3 Suggested Answers
WebTeligent
  • 42 Answers
SOURCE: Screen wont stay up.
I used a small screwdriver tool set from Radio Shack (about $15) and then I used http://www.irisvista.com/ guides (free) to get into the guts of the laptop. These guides are step by step and easy to follow. They didn't have my model, but they have a similare on and the info helped me get mine changed. Mine had gotten rock hard. Read the front page of the site for cautionary information in toshiba laptops as there are small parts in there. You want a working laptop when it's finished.
Posted on Nov 09, 2007
  • 92 Answers
SOURCE: have PS245E-06VMY-4C Toshiba satellite laptop but
Im sure you can get them but be very carful because thats where the leads join to the screen to give you pictur. To be honest I would bring it to a repair center and that if there is a problem you have come back...
Posted on Nov 17, 2009
Testimonial: "Its all a matter of if its do-able at a cheap enough cost or not to DIY without mucking things up. Quoted £20 to take the case off just to see. Thanks"
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
How do I change the hinges on my Toshiba P505D?
Remove the four rubber bungs at each corner of the screen cover then remove the four screws.
Luckilly Toshiba have thought about this problem!
If you offer the ninges up to the side of the screen, you will see how it is fixed.
Remove the covers fron the underside and the hard drive unplugs WITH CARE!
Unscrew the suround screws from the base and remove the top cover.
You can leave the keyboard in place.
You will see where the hinges fit to the base.
Replacement is the reverse.
Hope that helps.
Nov 29, 2010 | Toshiba Satellite P505D-S8935 Notebook
The right hinge on my screen is broken. Can it be
Here's a link to hinge repair procedures...
http://www.laptopka.com/2007/08/01/replacing-satellite-a45-broken-hinges/
It also has a link to search for the replacement part you may need.
Jan 01, 2010 | Toshiba Satellite A45-S250 Notebook
The display screen does not sit any viewing angle.
More than likely both hinges are broken (the screen pivots to the hinges). Nothing to do but to replace both L and R hinges.
Dec 24, 2009 | Toshiba (SD-R2412) for Satellite A10, A15,...
Have PS245E-06VMY-4C Toshiba satellite laptop but screen has been forced back breaking hinges. do you have replacement parts?
Nov 16, 2009 | Toshiba Satellite 2450-401 Notebook
The hinges on my Toshiba Satellite A85 Laptop are broken....Can they be repaired?
The hinges can't be repaired, but can be replaced. It's feasible to do it yourself if you're tech savy. Just look online for guides that show you how to replace the hinge on any toshiba laptop and you should get an idea how to do the replacement step by step for this specific model. I work for Computer Repair NYC and i have to fix this problem a lot, you can get the hinge on ebay.
Oct 02, 2009 | Toshiba Satellite A85-S107 Notebook
I am looking for hinges for my toshiba satellite a45 s150 laptop. are there any other brands of laptops that are interchangable with the toshiba, or is there another toshiba that is interchangable with...
There might be other models that will work with your laptop. However, to be safe, I would look for someone selling the exact parts you need on eBay.com. You can probably get a used case with the hinges for dirt cheap. Just type in your model in the search section on ebays homepage.
Mar 20, 2009 | Toshiba Satellite A45-S150 Notebook
Loose screen hinges
You can't. They're worn out and the way they're manufactured doesn't allow for a easy tightening unfortunately. I would pick up a new / used pair from ebay and then just swap them out.
Feb 20, 2009 | Toshiba Satellite A45-S120 Notebook
Cover will not stay opened
It sounds like you need new hinges for your computer. I didn't see any for your particular model on eBay which would be the best place to look but you may be able to contact Toshiba and order replacement hinges. To replace the hinges, you will need to remove the bezel from the LCE screen and possibly the power button board, depending on how your particular laptop is put together.
Jun 21, 2007 | Toshiba Satellite 2415-S205 Notebook
Toshiba Satelite 5205-S505 Notebook Logo
1,009 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
