Question about Wrangler Jeep Twin Stroller
Jeep wrangler coil pack problem
I have 2001 Jeep wrangler (6 cylinder). Engine started to idle rough and check engine light came on. The code was cyclinder 1 and 2 misfire (primary and secondary coil).
I replaced the coil rail. The codes are now cylinder 1 and 6 misfire. I changed plugs in 1 and 6, but no help. I checked resistance on the 4 four pins of the coil rail, but they all show shorted together.
Any ideas.
  • enzeddered Dec 06, 2007
    Hi my '97 Nissan rb25de is doing the same thing, runs smoothly above 3000rpm but u can still hear it misfiring occassionally. I stopped running it asap but during tests cold idling its now emitting an alarming white smoke. have replaced plugs without success, and before moving on to replacing ignition system componentry ad hoc, I thought it might be prudent to not rule out injectors since its been run low on fuel for an extended period. idles rough, returns dett fuel consumption figures,alas, without the accompanying excess of power expected from a turbo. this is the non turbo, engine check lamp has not lit, we do not have any error codes to work with, yet.
Replace spark plugs individually
Replace coil packs individually
Wynns for fuel injection systems/moreys/motorup etc etc
Test all fuel and injector system sensors, meters, fuses, connectors, plugs etc
Tow to automotive electrician
Learn more about automotive electrical systems
Posted on Dec 06, 2007
2001 chevy cavalier code po303 how to fix it replaced the spark plugs how to fix it it has a rough idle, weak acceleration ce light starts flashing on acceleration and hard to start
change the ignition coil pack common problem p0303 means cylinder 3 misfire and the coil pack are know to go out on these particular models
Apr 07, 2017 | Cars & Trucks
2001 Mazda Exclude 3.0L rough idling when cold
Change your pcv valve and clean your throttle body, then flush system fuel system with a can of Seafoam.
Oct 03, 2017 | Cars & Trucks
Horrible Random misfire in car
This is common issue with Infiniti I30 1999-2001.
When the coil packs fail they burn up components/parts on the engine computer ECU. If the problem gets worse, you will need to replace the ECU or have it rebuilt.
Is your check engine light on?
You might also get code P0505
Technical bulletin also recommends to replace
The Idle Air Control Valve MUST be replaced prior to re-installation of the ECM, or immediate damage to the computer will occur again.
http://www.myairbags.com/product/ecu-infiniti-i30-2000-2001
Common Failures:
  • No Start, Hard Start, Engine Stalls
  • Rough Idle, High Idle, or Idle Up and Down
  • Misfire to one or more cylinders
  • No signal to the ignition coils
  • Engine Trouble Codes For Idle Control Valve (IACV)
  • No Communication With Computer
  • Replacing IAC Does Not Fix The Problem
Jul 24, 2017 | Infiniti Cars & Trucks
Sport Wrangler 6 cyl. Engine lite flashing. Diagnostic tool lists code PO305. I looked it up and it states misfire in cyl #3 & 5. How do I fix this?
Check the plugs, wires and coil pack for these two cylinders. Most lilkely it is the coil pack, they work for 2 cyclinders at a time. cylinder motors use 3 and 8 cyl moters use 4 of these. If your und=sure where the coil pack is, follow it backwards from the spark plugs.
Jul 08, 2011 | 2002 Jeep Wrangler
How do i fix my 2001 cadillac catera idle problem. ive tried fuel injector cleaner, changed the spark plugs, and o2 sensors, but it still idles rough and im throwing these codes. bad o2 sensor bank 1...
The problems you are describing indicate to me that you likely need to replace the coil pack that runs from the spark plugs ,and the plug wires end up at it.It also may be the spark plug wires,get a water bottle and spray the wires after dark and if you get a light show from them then replace them,if not,replace the coil pack.
Jul 15, 2010 | 2001 Cadillac Catera
Wrangler Jeep Twin Stroller Logo
2,593 people viewed this question
Top Wrangler Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Wrangler Baby Gear Expert? Answer questions, earn points and help others
