Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
My frigerator I have a side by side and the divider between the freezer and frig is extreamly hot to touch. It goes up the middle and down and to the freezer side of the frig. the freezer is working but the frigerator seems alittle warm. it's about 48 degrees. HELP!
  • jomadato Nov 15, 2007
    It worked!!! My husband did not believe me when I told him what was possible the problem and went and called the repair man. Well before he got to my house my son and I cleaned out the fridge underneath and with getting the dust bunnies and a deydrated mouse(YUCK), the fridge works. I told my hubby he needs to pay me the 60.00 to fix the fridge. we cancelled the repair man!!
    Thanks alot!
  • 248 Answers
This will get warm. If very hot check and clean coils in front, underneath. Also check fan behind rear panel. It should be turning when the unit is running. Also check for door not closing properly.
Posted on Nov 12, 2007
  • Gerald Griffin
    Gerald Griffin Nov 15, 2007
    Good for you. You'll also cut he run time dramatically.
Gasket between frig and freezer is darkening due to very hot surface on divider between sections
If it is that hot you really need to get this checked out ASAP. It could become a fire hazard.
Mar 12, 2014 | Admiral Refrigerators
My refrigerator is hot! To be clear, the frig is cooling, but the divider between the frig and freezer is so hot that it almost burned my arm! The lower part of the freezer is defrosting as well.
Your condenser grill under your frigerator is dirty and not able to get rid of the heat. If you take off the front grill and the back panel and vacuum it out or better yet, blow it out with an air compressor, it should solve your problem.
Also make sure that the condenser fan is operating because that would also cause the same symptoms.
Aug 07, 2011 | Hotpoint HSS25GFP Side by Side...
Refrigerator is freezing
if you turn up the temp in freezer and down on frig side and frig still freeze's than more than likly you have a bad frigerator thermastate.
Nov 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore elite side by side w/ middle divider super hot
absolutely not
that middle peice should be hot to the touch
this is the mullion heater or yoda loop in the old days
this is what controls moisture from entering the unit
when you open the dooor
mine has been running for 7 years no worries
Oct 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Frig not very cold & metal between freezer and frig gets hot
Poor cooling and a hot divider mean that air is not moving effectively over the condenser coils under the fridge. Check to see if the fan is blowing under there while the compressor is running. If not, then the condenser fan has failed and needs to be replaced. If it is, then use a vacuum with a long nozzle to give it a good cleaning under there.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore elite side by side: hot divider
This is normal. There is a heater in this panel to stop condensation sweating between the doors.
Feb 23, 2009 | Kenmore Refrigerators
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
478 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
