When a station is tuned in the unit will decode the incoming clock data after 2 minutes will display the correct time when the 'DSP' button is pressed.
Note: some stations do not transmit a PTY or CT information & therefore the clock display may not be available.
For clock setting it is recommended to tune to a National Radio Station.
Hope This Helps.
check the sound setting on the sky box go to setting, then sound. audio out stereo digital audio out optical (dolby D) digital audio output hdmi (normal) digital audio output delay (0ms)
this is how the settings should be digital out put hdmi only works with full HD 3D tvs.
With the unit on, press and hold DISP until the clock begins to flash, then release. Press TUNE << to adjust the hours and TUNE >> to adjust the minutes. Press DISP momentarily to save the selected time.
And to save some time here is what i found for setting the clock:
The 24-hour system is used for the clock. 1 Press [DISP]. (clock display) 2 Hold down [DISP] for more than 2 seconds. Hour blinks 3 Adjust the hour. Hour entered [>>]: sets the hour ahead. []: sets the hour back. 4 Press [DISP]. Minute blinks 5 Adjust the minute. Minute entered [>>]: sets the minute ahead. []: sets the minute back. 6 Press [DISP]. Completed Notes: • "ADJUST" is displayed before adjusting the clock. • Hold down [ or [>>] to change numbers rapidly. • When "NO DISC" is displayed, the clock cannot be adjusted. Clock Display at Power Off Press [DISP] to change the display. Display off Clock display (Default)
Hold down iPod/MEM/C-ADJ till it flash's 24 Hours, choose between 24 & 12 hour clock, press MEM again to move onto hours, MEM again for minutes, MEM again to save the time
Changing the general settings (PSM) You can change the items listed on the next page by using the PSM (Preferred Setting Mode) control. • The PSM items are grouped into five categories—“Disp (display),” “Clock,” “Tuner,” “Color,” and “Audio.” Basic Procedure 1 Press and hold SEL (select) for more than 2 seconds so that one of the PSM items appears on the display. (See page 23.) The currently selected category is shown on the left side of the display. 2 Press 5 (up) or ∞ (down) repeatedly until your desired PSM category appears on the left side of the display. 3 Select the PSM item you want to adjust. 4 Adjust the PSM item selected. 5 Repeat steps 2 to 4 to adjust the other PSM items if necessary. 6 Finish the setting. To set clock—Clock Hr, Clock Min You can set the clock using the PSM control. 1 Press and hold SEL (select) for more than 2 seconds so that one of the PSM items appears on the display. 2 Press 5 or ∞ repeatedly until “Clock” is selected as the PSM category (it is shown on the left side of the display). 3 Press ¢ or 4 to select “Clock Hr (hour).” 4 Turn the control dial to adjust the hour. 5 Press ¢ or 4 to select “Clock Min (minute).” 6 Turn the control dial to adjust the minute.
Press and hold the SEL button to get into the menu that includes clock settings. Use the << and >> buttons to select "Clock HR" and "Clock M". To adjust the hours or minutes, use the volume controls. When you're done, just press SEL again.
