Question about Grundig Traveller Clock Radio
LCD display not showing digits
I have a Digital FM clock radio, that has been working since last two years. Recently the display became blank though no shock or field is applied.
After changing both the cells (AA size 1.5 Volt ) the display is blank?
Could you help in solving the problem? Is there any authorised service centre for Grundig in India? If so can you furnish me the contact address.
Manas Kundu ( manas_kundu@hotmail.com)
SOURCE: Clock
Radio can be on or off. 24 hour clock only (11:00pm = 23:00hrs). 2 clocks Time I and Time II. Select one or the other by pressing TIME 1/2 button (shows in display at top center). To set, if it is 23:00hrs, press 2 3 . 0 0, then immediately press TIME 1/2 button.
Posted on Jan 20, 2008
rolltape
  • 58 Answers
SOURCE: I have a Grundig Satellit 500 "Radio Boy"
If you sent it in 3 times, then I would suggest getting a new one if you know for sure that other's work in that area. If other's don't work, then then you have some type of interception between the radio waves and your radio. There is nothing I can do about that, and probably nothing you can do.
Otherwise, you should get a new radio.
Posted on Mar 16, 2008
  • 9 Answers
SOURCE: Grundig Satellit 800 display problem
HI,
THAT IS COMMON WITH PLL TUNERS THAT THE SLIGHTESS
TWEAK ON THE TUNING KNOB WOULD MAKE THE DISPLAY MOVE .COMMON ON DIGTAL PLL TUNERS........
Posted on Feb 07, 2009
kb8dns
  • 494 Answers
SOURCE: Grundig Satellit 800 LCD display doesn't work correctly
If the radio uses memory batteries, try changing these with new alkalines. The microprocessor needs this power to drive the display.
Posted on Feb 10, 2010
SOURCE: We have a Grundig S350DL radio that was my
Hold down the power button for a second or two when turning it on to disable the timer. For AM reception issue, you could insert both ends of a long wire into the red and black connectors on the back to act as an extra AM/shortwave antenna, or connect a wire to a pipe, oven, or other grounded object and plug it into the black connector in order to improve reception. Those connectors snap to hold the wire in place.
Posted on Apr 08, 2010
I can't find how to change the time for the alarm system for a Alphaline 150i digital radio alarm clock
PDF]Instruction Booklet - Sound Therapy and Relaxation Clock ...
www.conair.com/instruction.../07ps111_su7_ib.pdf
Conair CorporationThe LCD display will show the current time of ALARM 1, reset time. ... The Conair Sound Therapy & Relaxation Clock Radio System can be used with a cord ... 1) 10 high quality digital recordings .... 150 Milford Road, East Windsor, NJ 08520.
Muse - Alarm clock radio
www.muse-europe.com/en/products/alarm-clock-radio
Catalogue Products, Cat?gorie Alarm clock radio. ... M-125 CRB. Clock radio CD player with MP3 ... M-150 CR. Clock radio ... Automatic time-set clock radio PLL ...
[PDF]FM/AM Clock Radio - Sony
Jan 10, 2016 | Watches
Digital display goes dark from time-to-time...
Most likely its the digital display is burnin out, If your farmilar with electronics and soldering, you can just order the part and replace it yourself. If not shop around for a cheaper rrepair technician in your area.
Nov 13, 2007 | Cambridge Soundworks 88CD Clock Radio
Tip
USING THE CLOCK 1. NORMALLY THE LCD CLOCK DISPLAY (6) SHOWS THE HOURS AND TIlE...
USING THE CLOCK
1. NORMALLY THE LCD CLOCK DISPLAY (6) SHOWS THE HOURS AND TIlE MINIJTES.
2. BY PRESSING SET (9) ONCE THE MONTH AND DATE WILL APPEAR.
3. BY PRESSING SET (9) TWICE THE DISPLAY SHOWS THE SECONDS.
4. TO RETURN TO THE NORMAL DISPLAY PRESS SET (9) ONCE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How do you turn it on?
PDF]Download Manual - TIMEX Audio
https://timexaudio.com/media/uploads/product/.../T231_User_Manual.pd...
es you ntioned y order, her. Model T231. AM/FM CLOCK RADIO with DIGITAL TUNING. For questions or comments regarding this or other products, please call ...
https://docs.sony.com/release/ICFC218_US.pdf Sony CorporationAutomatic time set - When you plug the clock in ... The radio or buzzer alarm does not sound at the ... modifications not expressly approved in this manual.
SONY ICF-C1 FM/AM Clock Radio - Unboxing and Review ...
? 10:28
https://www.youtube.com/watch?v=xgYV7X_AVBI
Jul 14, 2014 - Uploaded by VISHKI
Poor quality, difficult to tune manual tuner, flimsy buttons. The major disappointment is that the clock only shows 24 hour format time. Sony sells ...
[PDF]instruction manual Bluetooth Wireless FM C
Jan 03, 2016 | Audio Players & Recorders
I have a Grundig Mini 300 handheld radio it rolled off my cloths and into the toilet, water got inside it,the digital display deosn`t work and shows up blank only the AM and FM still work.
It would need to be opened up to remove any salts or other things in the water. If the toilet water contained any flush additives they could have attacked the internal parts. In which case I think it would become very costly to repair.
If it is just a case of stuff causing a short circuit, then a clean and dry should solve it.
Nov 09, 2017 | Grundig Mini 300 AM/FM/SW Radio
I have a dc011 radio and it has no sound. i have checked the 2 fuses and they are good. the power comes on but no sound. Oh and i also have put in the 2 aa bat. what is my next step????? any info will be...
I had this problem recently. If you take off the front of the radio (don't forget 2 screws in back!) you will notice a set of black and red wires running from the 2 AA backup batteries to the digital display circuit board. The wires plug into the board with a little white plug. If you unplug this the display will fade to nothing. If you plug it back in it will display an unset digital clock format. This seems to reset the radio or something. And then it works.
Feb 04, 2011 | Dewalt DC011 AM/FM Radio
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
LCD display invisible on Sony ICF-2010
I found a posting that said this usually is a problem with weak memory batteries or a bad battery contacts. I replaced batteries and cleaned contacts and the problem was solved.
Mar 09, 2008 | Sony ICF-2010 AM/FM/SW Radio
Clock
Nov 11, 2007 | Grundig G4000A FM/AM Radio
Grundig Traveller Clock Radio Logo
46 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
