SOURCE: 1989 Cavalier Z24 3.1 rough idle and hesitation
its just white cuz i too the cat off..
cuz i thought my proble could have been to do with the cat...
cuz i lost power driving up hills and on highways now it just will start the die right away
or start and idle really bad...
any ideas???
i was thinking crank sensor.. or injectors
I had the same problem with my Z when i had it. But it worked when i just left the little hose off of the EGR valve.
SOURCE: 1999 infiniti i30t oil leak appear to be coming
cant tell you right where its coming from with out looking at it but pull out your spark plugs and if they are covered in oil it is your valve cover seal most common but if not it could be the head gasket sorry cant be more help good luck
SOURCE: O2 Sensor Problem?
yes an o2 sensor can cause those symptoms so can a minor vacuum leak --bad ignition wire -clogging fuel filter --sticking egr valve etc.
ENGINE HESITATES WHILE ACCELERATION
LOSS OF ACCELERATION
It
can be fuel pressure issue or it's the problem with accelerator pedal or its
clogged filters causing there.
There
are many other possibilities. I suggest you to go through the list of help
links mentioned below, these will help you to confirm where the actual fault
lies: -------
http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-engine-lean-codes.html
http://whatisbyme.blogspot.in/2012/05/2004-toyota-avensis-acceleration-and.html
http://technoanswers.blogspot.in/2012/04/wheel-hop-under-hard-acceleration.html
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html
These details will help.
Thanks.
