Question about GE 27923GE1 Cordless Phone
No dial tone or ring
Although other handsets are working with the same line chord, this handset is not having any dial tone and not working (no sound). However, when the handset locator is pressed, the handset beeps. The charge indicator is on when the habdset is in the cradle or when the handset is put into "talk" mode.
Posted on Jan 31, 2008
Handsets don't ring?
I assumed you are talking about your wireless phone. Are you worried about handset ringing or the incoming call ring? 1. If you want to check your handset ringing, you check it by calling from your base to your handset via INTERCOM. If it rings, then your hanset ringing is working. The trunk or the Tel Company dial tone is the one not going in to your phone. Hope this helps. Best regards.
Sep 01, 2015 | Lands Phones
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
My DECT6.0 telephone will not give me a dial tone nor answer any calls neither will the additional handset..Although my verizon direct line functions as it designed
Here are some tips, found online:
Reset the phone:
Unplug the battery in the handset, unplug the phone line from the base and unplug the electricity from the base. Leave everything unplugged for an hour or two instead of a couple to five minutes that way you can get more of an idea of whether your phone will work. After an hour or two plug in everything. If resetting the phone doesn't work then try the next step.
Check the surge protector:
Is the phone line plugged into a surge protector? The surge protector may have stopped working or blown a surge, a sudden burst of electricity, which may have caused the dial tone in your cordless phone to go. Unplug the phone line from the surge protector then plug it back in and see if you get a dial tone. It could be that the phone line plugged into the surge was loose or not plugged in securely.
Try a different phone plug, outlet.
Check the base:
Is the base dusty and have possible dirt in the prongs where the phone sits? Lift the base and blow off dust.
Check the handset for dirt.
Rub metal connections on handset and base:
Use a pen cap or coin and rub the metal connections on the bottom of the handset. Rub the prongs, metal connections on base.
Hope these suggestions help.
Jul 25, 2011 | Uniden Cordless Phone
The phone is not ringing and it is plug on charge and my wife got new battery for it too. What can i do to get it working? What size of Batteries cani use for this cordless phone
You need the specific battery pack: 5-2814 for the handset. This is a 850 mAh Nickel Metal hydride battery.
When I see a cordless phone that doesn't ring, the first thing I recommend checking is the phone jack and line itself with a second phone. I prefer to use a corded handset with a new phone cord to check for dial tone. If no dial tone at the jack, check for dial tone at the service entry box. If you have no dial tone at the service box, contact your provider. If it's only a problem at the jack, you will need to check your inside wiring.
To check the base, try a new cable (RJ-11) (double check the power as well).
To check the handset, first make sure the handset is fully charged (16 hours) and that the battery is fully installed. Does the handset beep when the Talk button is pressed? Next check that the handset ringer software is on. With the phone off (not in the talk mode), press the Mute/menu OK button. Use the Caller ID/volume (up/down) buttons to get to the Handset setup menu. Press the Mute/Menu OK button to access the menu. Use these buttons to check the Ringer Volume (should be on) and Ringer Tone. Press Mute/Menu OK to save the settings at each sub-menu. Check that the Do Not Disturb function is not on - this toggles with the Do Not Disturb button and should be noted on the handset screen when on.
If you have multiple extensions on the phone line, try unplugging some of them.
I hope this helps.
Jul 07, 2010 | GE T28821FE2 19 GHz Twin 1Line Cordless...
No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Mar 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
Failing to connect with phone line...
Have u connected the handset to the side below the hand cradle. & the line coming frm the wall should be connected to the line in on the printer & not the Extn. If its connected to the line in on the back of the printer,u should get a dial tone. U can also place a paper in the scanner & then press the option under fax till u get on hook dial.. that should also give u a dial tone.
Jun 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
GE 27923GE1 Cordless Phone Logo
383 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
