The air hose on my Aussie Air N13174 portable air conditioner is broken. Where can I buy hose replacement?
I need hose only for window unit, and I live in Sydney
    Top Expert:
  • 14,162 Answers
Take a pieceof the old hoe with you and go to a hardware store and have them cut you a new piece.
Posted on Jan 23, 2015
Testimonial: "Thank you. I have tried this and no hardware store that I have visited have been able to help me. They direct me to suppliers who redirect me to hardware etc."
SOURCE:
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
Daijitsu n13174
Check to see if you have the right outlet and plug. You should have no problem wiring it,fairly easy task! Make sure you have the right voltage parts!
Jan 14, 2014 | Heating & Cooling
Window kit dimentions i have a window 18 inch wide
The portable AC units generally have a customizable, exhaust hose window, termination kit that comes with the unit.. In other words it can be cut to fit. The one that comes with the unit will fit casement windows, as well as sash windows.
To further assist you, I have included a link to the Owner's/Installation Manual for the model you referenced. You may download and print it if you like.
http://www.air-conditioner-home.com/manuals/ac-12000.pdf
Hope this helped you. Please let me know. Thanks.
Jun 13, 2011 | NewAir AC-12000E Portable Air Conditioner
I need to get an on-line manual/problem w/hoses thru window
www.managemylife.com/mmh/owner_manuals/17647/AMANA-Air-Conditioner-Room-(42)-L0523054
Jun 01, 2010 | Amana AP095R Portable Air Conditioner
Hot air coming out of back
portable air conditioners mainly have two hoses one hose is exhaust thats the one that is blowing hot air. the one pulling is return.. the hot air blowing out should be exhausted to the outside. the blowing air needs a hose and to be laid out a window the back should have model and serial maybe product number. the two holes are either 4 inch or three inch and most portable units other than hand me downs come with a window frame that allows the hot exchanged air to go outside and cooler air to be used for heat exchange.
May 28, 2009 | Maytag NMPEB08F2A Air Conditioner
Need a manual for Fijita N13174 Air conditioner
Yes if the unit is not outdated by manufacture. Try googleing the manufacture.
Feb 06, 2009 | Heating & Cooling
Air exhaust hose gets extremely warm
The Pinguino's exhaust pipe has to be attached to the window bracket to direct the air hot air out of the room, otherwise the room can't cool properly.
The owner's manual has several troubleshooting remedies for you to try:
1)  If the window is open, close the window. 2)  If there is a heat source in the room (burner, lamp, etc.), eliminate the heat source. 3)  If the exhaust hose is detached, connect the exhaust hose.  (My recommendation is to connect the exhaust hose to the window bracket and direct the air outside.) 4)  If the air filters are clogged, clean or replace the filters.
Remedies that aren't mentioned in the manual, but you might find helpful:
1)  Make sure that there are no kinks in the hose, and that the hose either remains straight or has a gentle curve when directing it into the window bracket.
2)  A sunny window reduces the maximum power and efficiency of the unit.  Placing it in a sunny window reduces your BTUs by at least 600, which means the maximum square footage of cooled space is reduced.  Cooling a kitchen requires at least 4,000 BTUs alone, which is nearly half of the unit's BTUs.  Try to place the unit by a window that receives minimum to no direct sunlight.
Finally, stating the obvious, if the room isn't cooling, the room is too large for the unit.  The PACL90 cools up to 400sqft.  Bear in mind that the air from these portable air conditioners cannot move around corners very well, so try to set it by a window in the central part of the room.
Jun 13, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Danby dpac7008 portable air conditioner
I want to know how these portable air conditioners are supposed to be set up. Do they have to be on the same as the window out of which the hose goes? If the window is 4.5 feet off the ground, does the air conditioning unit need to be put on a table to make it and the window on the same level?
To the best of my knowledge the unit can stay on the floor and included the product features listed below and it does have a dehumidifier reservoir with direct drain and to make sure if you use the drain hose that the hose is higher than the item that you are draining the water into or you can elevate the unit so that the hose can drain outside and out the window - but you can also drain the water into a bucket or some thing that will hold water. I hope this will help you…..
Product Features
picexporterror From our expanded online assortment; not available in all Best Buy stores
picexporterror 7,000-BTU cooling capacity lets you cool rooms up to 250 sq. ft.
picexporterror Electronic temperature controls let you adjust the temperature in 1° increments for precision cooling; 3 fan speeds
picexporterror Dehumidifier mode removes up to 45 pints of moisture in up to 24 hours; 6.3-pint dehumidifier reservoir with direct drain
picexporterror Auto on and auto off timer
picexporterror Overload protection helps protect the air conditioner from power drains and surges
picexporterror Mesh filter is removable for quick and easy cleaning
picexporterror Includes remote
Apr 06, 2008 | Danby DPAC9030 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
