Question about HP LaserJet 1020 Printer
Print sharing command in linux - HP LaserJet 1020 Printer
  • 4,402 Answers
Posted on Dec 13, 2007
ES9410 - PDF jumbled printing
Assuming you are using MS Windows then install FoxIT pdf reader which allows command line printing on Windows. Go to to get it. Make sure your OKI printer is the default.
Once installed you can print using the command, from my dusty memory -
Reader.exe /p MyFile.pdf
I don't use Windows any longer, now exclusively Linux, so I might be mistaken.
Cheers, Martin
Nov 07, 2013 | OKI Office Equipment & Supplies
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
I have sumsang SCX3200 & I want to print my some Document & figer frm dos mod. Windows Xp is runing on my desktop pc
DOS applications cannot print on USB ports, but there's a workaround by using a share and the NET USE command, first create a share of that printer check this site:, (take note of the name you gave the shared printer) than you use NET USE command to connect the shared printer to a virtual port (LPT2) first click on START, than RUN, than type CMD than hit enter, type the following command " net use lpt2: \\\(shared printer name) /yes " than hit enter, if you have a " command completed successfully " than you have your shared printer connected to a virtual port (LPT2) now it is just a matter of setting your DOS software to print to LPT2... and VOILA! it prints...
Jun 25, 2011 | Office Equipment & Supplies
I backed up my windows XP drive to an Iomega usb drive. I can read the usb drive on that machine and on a Fedora Linux machine, but, NOT on other Windows machines. It won't display the directories/files,...
This is probably due to user restrictions. linux is having no problem, but only the user in windows that created the files can view them.... unless you can change the sharing properties.
right click on the files/folders properties / sharing / advanced sharing, and enable sharing
Sep 30, 2010 | Iomega (33090) 250 GB Hard Drive
Hp laserjer p1008 printer wants to share with 10 hosts but printing not done properly by shared users so pls assist me for proper printing through network (Domain) host?
Please check your LAN settings and cross check your printer is on shared mode and check all the computers that all are having install that printer whatever the want to shared by them.
Sep 29, 2009 | HP xw4600 Workstation Linux Installer...
Linux print to eStudio 232 printer
Did u install the driver?
Driver can be downloaded at below link:
Aug 05, 2009 | Toshiba e-Studio 232 Black and White...
How i transfer data from window to linux
Depending on your linux distrobution, you will need to check the /etc/samba or /etc/smb configuration file, within that file there will be a place to set your windowsfile sharing password. then you will be able to transfer data across the local network between your linux / windows machine again..
however, if you've actually changed the password for the linux user account that enabled the samba file sharing, you will need to either remember that password, or set a new one from the root account byt typing the following command in a terminal / bash / shell session:
Task: Set or change user password Type passwd command as follows>
$ passwd <user>
Output: Changing password for <user>
Enter new password:
Retype new password:
passwd: password updated successfully
NOTE: when typing the password, you may not see the password you are typing..
You need to replace <user> with the username you are changing the password for.
May 25, 2009 | Dell Dimension 1100 PC Desktop
Can't delete, can't format... MSS II
I was just dealing with this problem. Well, at least now you know how secure linux is now. It is not easy to make changes to linux partitions if you don't have administrative rights. You need to be root and have administrative rights on the partition to make any changes on a partition. You also need a partitioner. If you have linux, download a partitioner. If you don't have linux you can use a Live CD.
Jul 07, 2008 | Maxtor Shared Storage II (S01R320) Hard...
Networking with windows
Hello there.
Nice to see more people using Linux and Ubuntu. For information on how to share your Ubuntu folder to linux, over file sharing click here
You basically only need to right click the folder you want to share, in Ubuntu, then enable sharing and when prompted to install services, tick the box called 'Install Windows network support'
Hope this helps.
ps: if you haven't seen the Ubuntu community documentation, click here
Apr 13, 2008 | Computers & Internet
Cam is not braodasting
Linux and UNIX rpcinfo command help If broadcasting is not supported by any transport, an error message is printed. ... This is a generic option, and can be used in conjunction with other.
Linux and UNIX ifconfig command help.
Good Luck, Follow instructions, Please dont for get to Vote/Thank You.
Dec 25, 2007 | Acer Aspire 3610 Notebook
HP LaserJet 1020 Printer Logo
44 people viewed this question
Ben Johnson
