SOURCE: Sputtering, chugging, black smoke - won't restart when hot
check your tail pipe for a "clog" engine not breathing correctly.
SOURCE: i have a 2000 fisher
if it makes klic,klic,klic sound it may be the solenoid relay it cost about $30,try that
SOURCE: fuse blows when shift in reverse
Am I correct, the turn signal fuse is blowing when you put the manual shifter in reverse?
Let me know.
Regards
SOURCE: I have 1998 Chevy Silverado with over 200,000
I have a 98 chevy silverado also. I had same problem. My problem was located in the battery terminal. You need to take the terminals screws off and clean them good. You can not tell by justing looking at the terminals from fixed position. The corrosion was on the thread of the bolts itself.
