I've tried using the pin hole reset a few times, and that doesn't work. I've also tried leaving it off and not charging for a few hours.
SOURCE: my toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
try to hard reset or soft reset, for this procedure search on gogle.com how to reset tablet, that will be helpful.
(will not charge or power on)I sent my smartphone in for repair the other day.They told me it was water damage in the charging point
i have never had it near water but apparently having the phone in high humidity places is common for it to happen eg talking on phone under bus stop in the rain, having phone somewhere in bathroom while having shower,
holding phone over hot coffee? hope you get it fixed :p
SOURCE: wont start up the screen only displays the android
Try a master reset:
