SOURCE: esp dashboard warning light is constantly on... TT quatro 2002
warning lights are usually got to do with the electronics in the carm so you should go to a mechanic and ask him to check the cars electronics which is free and he will probably say your electronic wiring is smashed the cheapest thing to do is rewire your car it would cost 100-250 euro where as if you got the car comprimised it would cost 700-900 euro
SOURCE: 2002 Audi A4 Esp Light comes on, car turns off when I have to sto
I had the same issue with my '05 A4 1.8T. Turns out it was the RPM sensor. Audi tried to tell me it was teh fuel pump and the cam-shaft positioning sensor. Paid for teh fuel pump replacement and it died 6 blocks from the dealership. Then they replaced the RPM snesor, works great now... Except it's still an Audi.
SOURCE: Engine management light come on on an audi tt 2001
Really need the codes when the light comes on. Stop by advanced auto parts and have them read it, or buy a $50 tool. Will save you hundreds with an Audi.
Most likely is MAF sensor. Not as scary as sounds, and you may be able to fix it your self if you can twist a screwdriver.
Are you getting any coolant warnings?
SOURCE: I need a description of dashboard warning lights
i have a light that comes on my audi a3 1.8t dash board .it is round with a cross through it and like a little box on top can any one tell me wat this is thanks
SOURCE: light come on saying esp on my dash whats does it mean
traction control
The "ESP" system helps correct oversteer and understeer by breaking the inner or outer wheel as needed to get the car back on a straight path.
lets you spin tires
