SOURCE: 2006 Humer H3, Won't start and electrical resets itself
Check the battery terminals real good.Make sure they are clean and tight.Check and see if any of the side terminals are leaking. As far as the blower motor.It is more than likely that the blower motor resistor is bad.It is located by the blower motor.Hope this helps.Good luck.
SOURCE: BA Falcon 'door open' light is on, can't lock
Hi I have the same problem on my BA XT Falcon
Strangely it only happens after it's rained on my car (usually overnight) I then notice that the drivers lock is up and will not lock again until a nice sunny day comes and I leave all doors wide open for hours and hours!! Then all of a sudden once closing all doors normally the little dash door light turns off, and I can again lock the doors
Since it rained all last night here, guess what? It happened again!
So I've checked everywhere and cleaned and you name it, but nothing, I'm positive that when a warm sunny day comes again though, all will be ok.
Most annoying issue ever.
Where is this tiny bit of water that's causing this?
And which door?? Can I just disconnect one door at a time? I don't know it's driving me crazy!!!!
