At first it came out strong, then sputtered as usual, then stopped. Eventually after 5 minutes a very thin stream of water returned. And sometimes it would stop. I put the old filter back in, same thing. Not sure what happened, but it appears the new filter is fine.
Hello rodger;
my name is peter. i am a retired field service refrigeration technician.
you may have gotten a bad water filter. once, as a service technician we received a supply of bad water filters. all of us technicians have to return to our service calls and replace the water filters.
what had happened is the granules in the filter fell apart and plugged up everything, including the water solenoid valve filter screen.
remove the water filter and see if you can flush your system out by running your water dispenser with out the filter.
