Question about Exercise & Fitness
Instructions for heart rate monitor bowflex wr30m
Have tried to set the height for accurate calories burnt
r321567499
  • 74 Answers
SOURCE: how to figure calories burned
Try this link...I hope it helps. There is ann #877 cunstomer phone number also posted on this page.
http://www.iconservice.com/reebok/manuals.html
Posted on Jan 07, 2009
r321567499
  • 74 Answers
SOURCE: Every heart rate monitor - replacement battery doesn't work.
This link might be helpful...under the picture of the given product click on "great information about this product" It gives all the specs and troubleshooting ideas. I hope this is helpful.
http://www.heartratemonitorsusa.com/Pages/TRANSMITTERS/T31-coded.html
SOURCE: I have a cardio zone heart rate monitor but not the manual.
No further need for assistance.
Posted on Feb 16, 2009
SOURCE: inaccurate/intermittent heart rate info?
Here are the things I have noticed that help:
- enough moisture between the HR monitor and your chest. Apply water right before your workout to make sure it isn't all dry between the time you put on your monitor and when you actually started your workout.
- Make sure the strap is tight enough. Mine gets loose over time and the bouncing of running will give me inaccurate readings until I tighten it up again. You can test if this is the problem by using your hands to press the monitor more tightly against your chest - if that seems to fix the problem that a loose strap could be it.
- Use a "conductive gel" instead of water between the monitor and your chest. Conductive gels are pretty cheap.
Posted on Jul 03, 2009
SOURCE: I have lost the manual/directions for my Bowflex Heart Rt Monitor
The name of the manufacturer could help you, maybe those links will.
http://www.amazon.com/Fitness-Trainer-Strapless-Monitor-Pedometer/dp/B001UI7M9S
Bowflex heart rate monitors ]
Bowflex heart rate monitors pedometers step counters - Bowflex UK authorised heart rate http://www.bodybuilding.com/store/bowflex/classicstraplesshrm.html
Posted on Jun 16, 2010
Can I swim with the EZ PRO
You can if you want to. However those watches have problems and one thing that people complained about is the sensor button no longer working after swimming
Jan 29, 2014 | Bowflex WR30M EZ Pro Strapless Heart Rate...
Need a manual
You can get the pdf format.
Just make sure you have the adobe reader which is free for download. http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2016.pdf
Dec 25, 2013 | Bowflex WR30M EZ Pro Strapless Heart Rate...
My Skechers GOwalk Strapless Heart Rate Monitor (Basic; Model Number WR30M; Distributed by Sports Beat, Inc.) will not read the heart rate. I bought this digital watch new, and it worked in reading the...
Well it depends on how much you sweat.
The sensors need to be wet to read correctly.
You can buy something called Heart Rate Gel cost about $5 to $10
Some people just lick the sensors on the watch strap and it works until they can start sweat enough..
Hope this helps.
Nov 03, 2013 | Bowflex WR30M EZ Pro Strapless Heart Rate...
Bowflex
Jan 08, 2013 | Bowflex WR30M EZ Pro Strapless Heart Rate...
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
It appears my F6 monitor is not keeping accurant time on calories and heart rate. I like the watch but while checking my sitting heart rate is very low. When checking the heart rate on a blood pressure...
First you need to understand that the Polar system is a medical grade device and it is calculating calories based on specific information that you have inputed and heart rate data from your heart.
Most treadmills and other exercise machines use a much simpler counter that is height and weight based to calculate calories and are generally over generous with their numbers.
Depending on the blood pressure machine you are using, the pulse (not heart rate) is coming through the brachial artery, again not quite as accurate as measuring r-r variance from your heart. There is a ton of literature you can read if you are into the accurateness of the system, but I will sum up with saying that you actual calorie expenditure will be closer on the Polar than on most other devices outside of a hospital. As too the heart rate this is also true, so more likely you are getting inaccurate numbers from the other devices.
If you want pinpoint accuracy then you will need to use the Polar RS800 or S810 devices that measure and display true R-R.
Jan 12, 2011 | Polar F6 Wrist Watch
The Reebok Fitwatch 10S Calorie Counter
Yes when you are in time mode press the mode button 5 times this will be your calorie screen press the st/stp button to activate the calorie counter you will see in the bottom left corner it says CA ( meaning calories) and in the bottom right crn are the calories you are burning press the st/stp button again to stop then reset when you want to start again.Hope this helps can you help me? I keep pressing the sensor buttons and my heart rate does not appear what am I doing wrong ? Ive read my instructios inside out even returned the watch and got another but the same thing keeps happening ! Initial when I set the watch up it works then I just cant seem to get my heart rate to appear ????????? Thanks Nicole
Mar 24, 2009 | Reebok Fit Watch 10M Strapless Heart Rate...
How to figure calories burned
Dec 30, 2008 | Reebok Fit Watch 10M Strapless Heart Rate...
Exercise & Fitness Logo
298 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
